Old 07-10-2009, 06:00 AM   #1
Kevin
Default Timing question
Ok so i changed my hg. i wanna set my timing. so i know that u need to place a jumperand set the cams to the groves on the plate and the crank at 0, then put the cps making sure the thing lines up. then hook up the timing light to spark wire #1 and the other leads to the battery. i am aware that i adjust the timing by moving the cps.
my question is.. how do we set the timing to 10* by looking at the notch on the crank? where do we line it up because i do see the timing numbers on the plate behind the crank but there isnt any clear notches to line up with? am i supposed to eyeball it to the center of the number? and how do we line it up when the notch on the crank is at the fron and the numbers are at the back? just by eye?
Also the timing light i have has a knob with degrees on it.. do i leave it at 0?
Old 07-10-2009, 12:20 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Set the crank-pulley marker on zero, cygnusx1 set the timing light at zero also
Old 07-10-2009, 02:45 PM   #3
Kevin
there's notches? maybe it's just dirty. lol i'll clean it and look for it later. i didnt notice the notch on the crank pulley though. is there one on te outside and side too or something? because i only noticed it on the outside.
Old 07-10-2009, 07:52 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
Good write up HERE don’t forget this for a 7M-GTE, you can either use # 1 or # 6 HT leads for the timing light connection, as the coil pack fires pairs of HT leads. 7M-GE use # 1 HT lead only. The notch on the pulley is as in the diagram posted.
Timing question happysupraowner:) MKIII Supra 1 06-11-2009 06:47 AM
Timing question. supramacist MKIII Supra 53 04-26-2008 11:41 AM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
timing question (weed todd did) joel w MKIII Supra 6 09-26-2005 03:32 PM
Timing question DeDom18 MKIII Supra 1 08-17-2005 07:50 AM
