Old 07-06-2009, 10:33 PM   #1
GettaRobo
GettaRobo is on a distinguished road
Default The unfixable mystery problem
I have an 88 n/a auto supra from california, that has all the extra sensors and other goodies, with a faulty speed sensor. Other than that, the car runs fine except that if you floor it, the car will rev up to 4000k and then stop and not go any higher. If you push the pedal down 3/4 of the way, it will rev above 4000 up until redline. I have the car in at a mechanic that has knowledge of these kinds of cars. They've checked the fuel pressure, the distributor, they looked for some sort of rev limiter, they've looked for vacuum leaks, and nothing. I have no more ideas (nor does the mechanic) of what could be wrong on this car and it's really starting to frustrate me. If anyone has any clue as to what could be causing this, I would greatly appreciate your input. Thank you very much!
P.S. I have another car that is the exact same as this one from Canada that I'm using as a parts car. The mechanic suggested I get it towed there for random part swapping and I'm thinking I will have to resort to this but I'm hoping not.
GettaRobo is offline   Reply With Quote
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
