Old 07-18-2009, 06:07 AM   #10
carl johansson
carl johansson is on a distinguished road
Have you looked at the throttle cable? have someone sit in the car and floor it = while you watch the cable - maybe the cam lobe broke off or something stupid like that - so it's going back low throttle -
compare that to watching when you are at 3/4 throttle and it revs to redline.
I assume you took the fuel pressure after the fuel filter right?
It almost sounds like it's getting to much fuel at full throttle - did someone change the injector sizes? and isn't there an adjustable fuel pressure regulator? To much fuel at full throttle could be choking it off - while 3/4 is allowing enough air! It used to be a fairly common problem in carbed cars!
Just throwing out ideas - I don't know!
Carl Johansson
carl johansson is offline   Reply With Quote
