Old 08-01-2005, 09:37 PM   #1
Supra Guestz-driver
Guest
Posts: n/a
help... my engine light turns on when i drive, then goes away when i restart the car again...
Old 08-02-2005, 02:50 AM   #2
Riddick
Riddick is on a distinguished road
going to need a little more info then that, like the years a good start, also im not sure if my scaner even hooks up to the Supra or you have to ground pines in the dignostic port, but there is a port on the front just after the battery, it could be somethng as simple as on O2 or as bad as an intake leak, some newer modlues will have more sensors in them to figure out whats going on, i would say take it to a shop and have a mechanic scan the car and tell you the code, sometimes you can but those cheap code readers at the cheapo auto store, those sometimes work but are mostly not wouth the money.
mind you my snap-on motus scaner id worth.............like 10,000..........im glad my shop picks up those bills.
Riddick is offline   Reply With Quote
Old 08-02-2005, 03:10 AM   #3
Poodles
Poodles is on a distinguished road
you can jump pins on the connector on the service port and the check engine light will blink telling you the codes. Get a service manual on how to do this, plus it will tell you what the codes mean, and possibly how to fix them.
Poodles is offline   Reply With Quote
Old 08-02-2005, 03:46 AM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
yep read the diagnostic in the faqs and that will tell you how to do it and what the code means and how to repair
get a bit of wire, put one end in T and the other end in E1, turn key to ign watch the blinks... count them... then relay them back here
Pics of my build.
Do a diagnostic first!
Old 08-02-2005, 03:48 AM   #5
Guest
Guest
Posts: n/a
sorry.....i got a 87 supra turbo from canada with the 7mgte motor.....with 5spd
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
check engine light ironcobra2002 MKIII Supra 4 11-05-2005 04:07 AM
Engine Light Supra91_ishot Non-Generation Specific Questions 2 06-08-2005 12:37 PM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
