Old 05-26-2009, 05:38 AM   #1
jcastro
Default dose the oil pump knock?
i had knocking on my bottom end so i whent in to replace the rod berings and found that they wrnt in bad shape, so i checked my mains. They mains looked almost brand new. I read in a supra add that they guys engine was knocking due to a faulty oil pump and dam it sucks if it is. How do i know if my oil pump is out and its knocking. Im gana try to check tomarrow if any tips it would help
jcastro is offline   Reply With Quote
Old 05-26-2009, 11:21 AM   #2
mirage83
Your oil pump won't knock. It might fail completely or it might work but not provide sufficient oil pressure, both of which could damage your engine and cause your engine to knock, but the pump itself won't knock. Worn wrist-pins can result in knocking too btw.
What's your oil pressure, at idle and at cruise?
Read that you just put in new rod bearings. Did you use a plastiguage to verify that the bearings you installed were the proper size?
Old 05-26-2009, 04:08 PM   #3
jcastro
the stock oilpresure gage reads a lil under the first line close to 0 so i know thats bad it use to read like at 40 as for the barings i used standerd size and im srry to ask but what are wrist pins and where are they located
Old 05-26-2009, 04:43 PM   #4
mirage83
Oh, that's not good.
Standard size rod and/or main bearings are almost certain to be undersized on a well-used engine. That's probably where your knock is coming from, but without a good inspection and check of the entire bottom of your engine it's impossible to know for sure. You needed a machinist at a reputable shop (if you don't have the experience to do it yourself) to mic everything out to see what size bearings are called for according to the amount of wear and tear on your crank, rods, etc. Putting incorrect sized bearings in just sets you up for rebuilding the bottom half again.
Incorrectly sized bearings could well account for your oil pressure problem.
The wrist-pins I mentioned are the pins which hold your pistons to the rods. A worn pin can cause all sorts of nasty sounds, and if it gives way entirely you can pretty much kiss the piston goodbye and more than likely the rod too.
Old 05-26-2009, 10:17 PM   #5
jcastro
ya the oil was almost at 0 and theres no shops down here whith a good rep that knows about turbo supras i think im just gana buy a rebuild one from a comp. i saw on line then try to go al out on my old one.
Old 05-26-2009, 10:37 PM   #6
mirage83
Spend your money well. A truly well-built engine is going to cost you more, but you'll be better off in the long run for having spent the extra money on it. That'll give you plenty of time to rebuild your old one to whatever spec you want for it.
Old 05-27-2009, 04:45 AM   #7
jcastro
thanks man so hows ur supra treating u
Old 05-27-2009, 01:56 PM   #8
mirage83
She runs, but is back in the shop right now so they can fix what their guy who installed the engine screwed up. Should be back out today or tomorrow, then I'm stripping the interior out to scrub the carpet and seats. Then it's on to compounding & polishing the paint to try and salvage it since I don't have the $ for a new paint job right now.
It was a car I rescued from going to a junkyard, been working on it about 1.5 years. Reman'd engine, cleaned and sealed gas tank, new fuel pump, new sending unit, lots of new parts in the engine compartment. It's a project.
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
MSD fuel pump? redmaro MKIII Supra 6 08-24-2007 04:09 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
