Old 05-23-2009, 11:15 PM   #1
thakiller009
thakiller009 is on a distinguished road
Default water pump
where is the water pump located at on a 7mgt
thakiller009 is offline   Reply With Quote
Old 05-24-2009, 12:10 AM   #2
craig
craig is on a distinguished road
its the thing the fan is bolted to...
craig is offline   Reply With Quote
Old 05-24-2009, 12:47 AM   #3
thakiller009
could the water pump cause the car to leak water
Old 05-24-2009, 02:36 AM   #4
mirage83
Can happen. Shaft seals could have gone out, or the gasket where it mounts to the block could be bad.
Old 05-24-2009, 02:57 AM   #5
thakiller009
i think it is the gasket where it mounts to the block when you stand in front of it is it to your right
Old 05-24-2009, 03:13 AM   #6
mirage83
Seriously, it's behind the radiator fan. The fan clutch mounts to a pulley which mounts on the WP shaft, just follow that back and you'll see the WP itself. If there's no sign of water running out along the shaft then it's probably just the gasket.
Here's a diagram of how it fits together...
Old 05-24-2009, 03:26 AM   #7
thakiller009
k thanks for the info and could i getthis checked out by a mechanoc
Old 05-24-2009, 03:55 AM   #8
mirage83
Yep. A mechanic could pressurize the cooling system for you to verify where the water is leaking from, tell whether it's just the gasket or the pump itself (the shaft seals aren't replaceable that I know of).
Old 05-24-2009, 04:20 AM   #9
thakiller009
k i will get this checked out when i get paid thxs
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
Water Pump!!! IHateHacks MKIII Supra 10 05-16-2007 04:44 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
Replace Water Pump? Benesesso MKIII Supra 3 03-31-2006 12:26 AM
1gte water pump streetbeast MKIII Supra 15 06-24-2005 08:02 PM
