Old 07-30-2005, 03:25 PM   #1
i have a 2 mm metal head gasket
i recorded 150psi on all six with little to zero difference between cyl.
just checking
the manual says 142 psi with an exceptable difference of 14 psi
Old 08-02-2005, 04:34 AM   #2
seems alright to me.. mine are usually between 150-160... so if they're all even and car still goes well... i'd say nothin to worry bout
Old 08-02-2005, 01:39 PM   #3
daiagaru2
daiagaru2 is on a distinguished road
note; when using synthetic oils your compression readings will drop slightly,but as long as all preasures are within the perameters,it's all good.this does not mean however that you will loose power.
daiagaru2 is offline   Reply With Quote
Old 08-03-2005, 11:11 AM   #4
i use synthetic
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Compression check question... Serge MKIII Supra 2 04-07-2008 03:49 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
5m-ge check connectors tonster MKII Supra 2 04-08-2006 06:54 PM
