Old 05-10-2009, 11:51 PM   #1
suprabahamut
Default Problem starting different times
It is a 88 supra, I usually don't drive it too much do to my other car is more economy with mileage. But when I do start it after a week it hesitates really bad. But the next day fine and even after that. But if it sits for more than 3 days it will hesitate again. I have done all maintenance to it, new wires, plugs, all new filters, fluids changed, everything covered in the manual I have done, except for the timing belt. So what could it be?
Old 05-11-2009, 03:35 AM   #2
azerty
azerty's Avatar
azerty is on a distinguished road
I think this is because the fuel evaporates, and it takes some turns for the fuel pump to fill the lines again. No wories, this is normal when not using u`re car for a long time.
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Old 05-11-2009, 04:49 AM   #3
suprabahamut
Thanks for the quick reply! Does your do this as well?
Old 05-11-2009, 06:47 AM   #4
azerty
azerty's Avatar
Yes, when I don`t start it for a few days, it does that.
HKS ssqv bov
boost gauge
K&N FIPK
550cc RC Injectors
Aeromotive FPR
Old 05-12-2009, 02:12 AM   #5
shaggydude1111
shaggydude1111 is on a distinguished road
another possivbility depending on climat could be moisture in the lined. If you dont drive a car often you should add dry gas to every tank.
shaggydude1111 is offline   Reply With Quote
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
mysterious starting problem stevanom MKIII Supra 7 11-14-2006 08:50 PM
starting problem Supraman MKIII Supra 8 09-26-2006 09:53 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
i have a starting problem johndawn MKIII Supra 4 02-16-2006 01:16 AM
