Old 07-29-2005, 10:31 PM   #1
Makavelli
Makavelli is on a distinguished road
I've got it narrowed down to 3 Supras...an 87 NA, and 86.5 NA and an 82.
Which is the most cost effective to tweak?
How much can I expect to spend to get er fast? (without a swap)
<span style='font-size:14pt;line-height:100%'>Stock...for now</span>
Makavelli is offline   Reply With Quote
Old 07-30-2005, 01:29 AM   #2
monkihead
monkihead's Avatar
of ur 3 picks...hmm...they're all pretty much equal. have you looked into an 86 or 85?
monique- better off dead
Old 07-30-2005, 04:19 AM   #3
Poodles
an 82 is a Mk2, which ARE lighter...plus they have a certain muscle car look to em. I'd have to look up stats, but I don't think the engine is that bad off compared to the 7m's. Personally, if you want to hang, you should try and find a turbo car...
Old 08-01-2005, 06:48 PM   #4
monkihead
monkihead's Avatar
82s are only lighter because of the fender flares and rear wing. a 7mgte into an 86 would be give the best power to weight ratio.
Old 08-01-2005, 06:49 PM   #5
monkihead
monkihead's Avatar
Old 08-02-2005, 01:34 PM   #6
daiagaru2
daiagaru2 is on a distinguished road
yes you can tweek a n/a engine,but not nearly as much as a turbo.n/a mods beyond exhaust ,intake and ignition timing are very expensive.next you would look to individual throttle bodies ,increased cam profiles, upgrading valve springs,porting the head,boring cylinders larger,all of this would cost you so much it would make your head spin.start off with a good condition turbo mk3 .this way you can upgrade more easily plus you will not have the dissapointment with the lack of power the n/a's provide.i once owned an n/a there were just as many problems as the turbo(blown head gaskets),once you drive a good turbo car compared to an n/a version trust me there is no going back.do it right the first time and you won't have to lie to yourself saying this n/a is fast enough for me.hope this helps.
daiagaru2 is offline   Reply With Quote
Old 08-05-2005, 07:01 PM   #7
Makavelli
I'm only lookin for about 50 more horses, short term. I plan on doin a turbo swap in the future.
Blitz MSTT Speed adjustment SunDan MKIII Supra 5 11-17-2009 07:41 AM
New to MK4 (Auto TT to 5-or 6 Speed TT?) Mattz32 MKIV Supra 2 11-01-2008 06:25 PM
speed o-meter or speed-cable help... hangsupra MKIII Supra 0 10-15-2006 08:54 PM
NA to TT 5 speed swap HELP Kboi781 MKIV Supra 3 04-11-2006 06:25 PM
