Old 03-30-2009, 11:54 PM   #1
BrunoD
BrunoD is on a distinguished road
Default no spark out of ideas.
figured id try another forum since everyone on mine seems to be stumped. i have an 86.5 supra that i dropped a jdm 7mgte out of a 87-88 supra in. the swap came with engine wiring harness transmission computer and igniter. all i had to do was drop it in. well i did that. everything is connected and i have no spark. the coils tested good. the cam sensor tested good as well. i replaced the igniter and still no spark. someone have any ideas?
BrunoD is offline   Reply With Quote
Old 03-31-2009, 03:54 AM   #2
Vacationtime247
Test for voltage at the coil. If there is no voltage going in to the coil, there obviously won't be any spark coming out. Pull off the distributor cap, is the rotor in place?
Best way to test for spark is to pull out a spark plug, insert spark plug into mouth with plug wire still connected, have a friend turn over the engine. If you spit the spark plug out, you got spark. lol
VT247
Old 03-31-2009, 04:26 AM   #3
BrunoD
thats a great idea. except for the fact it doesnt have a distributor. but i did try the spark plug thing. was still in my mouth. still no spark. and there is power going to all 3 of the coils.
Old 03-31-2009, 07:59 AM   #4
Vacationtime247
The coils should get a signal from the computer telling them when to fire. Have you checked for signal when the engine is turning over?
VT247
Old 04-02-2009, 01:33 AM   #5
BrunoD
yea i checked it. im not getting anything. what i did was pulled off the 2 pin connector found my batt voltage then put my dvom lead into the other connector cranked it over and nothing.
Old 04-02-2009, 03:41 AM   #6
Vacationtime247
Default Hope I'm helping.....
What sensor tells the computer when to give the coils a signal on the motor you have installed? Is it a cam position sensor? A Crank sensor? Check for proper voltage out at that location with the engine turning over. Another thought is to make sure you have all your grounds. Computers and sensors don't act right without a good ground.
VT247
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
need ideas theWeezL MKIII Supra 25 07-10-2006 06:23 AM
