Old 03-21-2009, 11:32 PM   #1
mkIII supra turbo gav
mkIII supra turbo gav's Avatar
mkIII supra turbo gav is on a distinguished road
Default over heating HG ?
hi just bought a supra turbo mk3 and ive changed the water pump but it still over heats no oil in water vica versa and none out the back engine sweet n ticks over fine i removed the thermostat no luck there the temp gaue hit the roof tho but engine didnt skip a beat n i couldnt hear any bubbling from the front could some one please shed some light cheers gavin
mkIII supra turbo gav is offline   Reply With Quote
Old 03-22-2009, 02:04 AM   #2
Quint
Quint is on a distinguished road
If its overheating, you should probably STOP driving it, Japanese cars HATE getting hot, your head will probably look like a waffle.
let it idle, take off the radiator cap and see if bubbles start coming up, its most likely a blown head, check your temp sensor first.
But jesus christ, stop driving the poor thing until you sort it out.
Quint is offline   Reply With Quote
Old 03-22-2009, 09:59 AM   #3
all sorted it was a blockage in the heater matrix runs a1 and stays cool
watch the vid http://www.youtube.com/watch?v=lb63Ob2bRTc
Old 03-23-2009, 03:50 AM   #4
jcastro
hi i was reading ur post and i have the same problom howd u find out it was heater matrix and what u do to fix it
jcastro is offline   Reply With Quote
Old 03-23-2009, 08:06 AM   #5
hi i took the hose off going into tohe matrix and used a hose from the tap on it and left it running till the water came through clear and fast
Old 03-23-2009, 10:17 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
You may still may have a problem with that in the summer, when you select the cold setting on the heater control; this operates a control valve on the bulkhead. (near the ABS unit on UK models) this shuts off any coolant going into the heater matrix. The coolant is then diverted back around the system from the pipe union at the rear of the head, which is the same as the heater matrix becoming blocked.
Old 03-23-2009, 10:22 PM   #7
i also changed the water pump which was leaking too
Bhg???? Over heating maybe head gasket? Thermo? AlexSchuSupra MKIII Supra 2 03-08-2009 02:12 PM
over heating problems, need help turbo_mk3 MKIII Supra 5 01-08-2009 05:04 AM
Help! Losing water and over heating, but no dripping?!?! Moses76 MKIII Supra 5 04-06-2008 12:32 AM
Another over heating problem.. newbsupra MKIII Supra 3 05-25-2006 08:26 PM
Heating problem Lee MKIII Supra 3 10-04-2005 11:50 AM
