Old 03-15-2009, 01:52 PM   #1
Paul_NJ
Paul_NJ is on a distinguished road
Default Crank Pulley Removal . . . again
I'm on 135,000 miles with an original timing belt, so while I'll pulling things apart to replace the oil seals on top, I thought I'd break the "if it isn't broke . . ." rule.
I searched and found a helpful thread several years ago discussing how to get the crank pulley off, debating the pros and cons of the "starter bump method" vs the "block the flywheel" method. Neither excites me much. What I wish to avoid most is removing the starter. Unhappy memories.
I've got a pretty strong 3/4" drive air impact wrench. Has anyone had success getting the nut off that way? I'd rather pull the radiator, if necessairy, that that lousy starter.
Then again maybe I should stick to the "if it isn't broke . . ." rule.
Paul_NJ is offline   Reply With Quote
1980 Supra Crank Pulley (Harmonic Balancer) steve6163 Non-Generation Specific Questions 7 06-18-2010 01:47 AM
Crank Pulley Removal go.stfu MKIII Supra 4 07-12-2007 11:16 PM
crank shaft pulley puller supramacist MKIII Supra 30 04-18-2007 02:27 AM
Main pulley removal. Kuban MKIII Supra 17 03-19-2007 07:04 AM
Crank shaft pulley.. MA70_858 Non-Generation Specific Questions 3 07-28-2006 04:47 PM
