Old 03-21-2009, 02:49 AM   #31
Vacationtime247
Default More pictures
Here's a few more pictures that I took.
VT247
ID:	1890   Click image for larger version
Old 03-24-2009, 11:56 AM   #32
Vacationtime247
Default Youtube videos
Here is a video I posted on Youtube.com of the Supra project.
VT247
http://www.youtube.com/watch?v=k2QtXIKyXH8
Old 03-25-2009, 08:04 AM   #33
Quint
Quint is on a distinguished road
Not my flava' But damn man, this project has rocketed along.
Well done! Looks like you have done a job that you can be proud of! You should have used a forced aspiration 1UZ-FE though
Congratz tho, You'll have to get a dyno and a 1/4mi run done
Seriously though... ditch the saw blades worst alloys ever!
Quint is offline   Reply With Quote
Old 03-29-2009, 01:27 AM   #34
Suprafreak
Suprafreak's Avatar
Suprafreak is on a distinguished road
It's not going to be a supra anymore if you swap for a non toyota engine. i think your painting ideas are wack mann.
proud owner of a fresh 87' supra
Suprafreak is offline   Reply With Quote
Old 03-29-2009, 04:37 AM   #35
Quint
Least hes done it rather than 90% of other people that own cars and just talked about it.
Old 03-29-2009, 11:26 PM   #36
Vacationtime247
Project has been stalled for about a week now. Been rainy and cold. Had some other things needing to be done too. Going to purchase 2, 1/4 pieces of steel, 8 X 8 1/2 inchs. Drill out the 4 indentions on the stock frame mounts. Then, set the pieces of steel on the mounts and cut a groove for the steering shaft on the drivers side. Drill holes through the steel to align with the frame mounts holes. The steel will also span the distance to the frame rails and will be welded on there as well. The engine mounts will rest on each of the steel braces. Sooooo..... the engine needs to come back out, again. *Sigh*
VT247
Old 03-31-2009, 08:05 AM   #37
Vacationtime247
Default Steel motor plates loosely fitted
Here are a couple pictures of the plates that will be used. The engine mounts will be bolted or welded to these plates. The plates will also be welded to the frame rails.
VT247
ID:	1914   Click image for larger version
Old 04-04-2009, 04:47 AM   #38
Vacationtime247
Here's my latest Youtube video. It's of the engine plates and mounts. It was pretty simple to fabricate the plates. The engine sits in there real nice.
http://www.youtube.com/watch?v=hacynXk4T8g
VT247
Old 04-05-2009, 07:57 PM   #39
Vacationtime247
Looks like the exhaust will be a tight fit on both sides. I'm purchasing a set that I think will work with the space given. Should clear the steering linkage on the drivers side and miss the firewall on the passenger side. I'm planning on running sidepipes as well. There is plenty of clearance for 2" exhaust between the front subframe and where the body frame rails begin to roll back under the car. A 5 ft piece of 2 - 2 1/2 exhaust will run the length of the mid section of the car front to back with turn downs just behind the doors. Here are a few pics of each side of the engine with it sitting on the steel mounts. You'll notice how much easier this engine will be to work on than the 7M. For anyone else who might eventually turn to the dark side and do a convertion like this, it's been pretty easy so far. The best part, it sits in there with only minor underbody cutting. The oil pan clears the subframe and so does the starter. The plates are pretty straight forward.
VT247
ID:	1923   Click image for larger version
ID:	1924   Click image for larger version
ID:	1925   Click image for larger version
Old 04-05-2009, 08:11 PM   #40
Vacationtime247
A few more pics of engine bay.
VT247
ID:	1927   Click image for larger version
ID:	1928   Click image for larger version
ID:	1929   Click image for larger version
