Old 02-18-2009, 03:59 AM   #11
tsupranami
tsupranami's Avatar
tsupranami is on a distinguished road
Yep, that could cause a problem. Let's hope that's it.
89 Turbo Targa 5spd, 18x10 w/275/35/18, 18x9 w/245/40/18, Brembo CD rotors, Hawk pads, SS lines, HKS coilovers, ST sways, 1 pc. AL DS, V3 shifter, RPSmax PP w/HPF ferramic disk, custom crank, Eagle Rods, JE pistons, Ferrea valves, BC 264 cams, Fidanza cam gears, Walbro FP, AFPR, RC660 inj., Blitz SUS, Lexus AFM, SP 47trim CT26, HKS SSQ BOV, 2.5" AL IC pipes/FMIC, Lipp turbo elbow, RT DP, Greddy SP catback, HKS FCD, AEM Uego WB, Apex'i SAFC, Apex'i AVCR, EGT, Fluidyne AL rad, Flexalite fans.
tsupranami is offline   Reply With Quote
Old 02-20-2009, 03:14 AM   #12
sd88supra
Default delayed!
I took off the thermostat housing, and there was no thermostat! Not only that, but the heater core was bypassed! My mechanic supposedly bypassed the heater core because the hose that goes into it was leaking and he couldn't find a replacement so it was a quick fix. At that it was done poorly, I'm more than sure air is getting in through there. So I go on to put in the thermostat, and the bottom bolt broke! So now I have to either drill it out or hammer a flathead screwdriver in to take it out (if any of you have done this before, please let me know how to go about it. I also bought a bolt extractor in case the hammering doesn't work).
I didn't have time to work on it until today, but I was delayed even more because the douchebags at Auto Zone and Kragen don't know how to find that hose without matching it, and I don't have the hose to match it. Does anyone know the diameter size and proper name for it? There's a good picture of it in the BHG repair sticky. The hose goes into the firewall on the driver's side.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
Old 02-20-2009, 03:57 AM   #13
spudz29212MKIII
spudz29212MKIII's Avatar
Since were talking about radiators and coolant I have a question:
I have one of those pressure release radiator caps, and after a trip to class or home it kinda fizzes out where the release tab meets the metal cap (hard to describe) like someone has a straw blowing bubbles? I bought a new cap yesterday and it still does it. Any clues?
Thanks
Zach
Old 02-20-2009, 04:25 AM   #14
tsupranami
tsupranami's Avatar
I usually use a dremel with a cutting disk to cut a slot into the bolt end big enough for a flathead. You can also replace the entire thermostat housing if you can't get the broken bolt out, as it bolts to the block with three bolts (two studs/1 bolt.)
As for the heater hose, it's a Supra. Which means that normal auto parts stores don't carry most parts for it (including almost all the molded hoses except the upper and lower radiator hoses). I believe the heater hose will be Dealer or junkyard only. Maybe someone is making them now, but for the past ten years, whenever I go to Schucks, NAPA, or the like, they have almost nothing available that is Supra specific, in stock or special order. That's why my dealer gives me wholesale pricing, since I order parts for mine and several friends Supras on a regular basis.
It's just part of life with such a limited production car. Toyota didn't sell many Supras (relative to their other models) so most parts stores do not stock any Supra-specific parts, and if available at all, they usually have to order them.
Spudz - Supras weren't designed to use valved pressure relief caps (the one's with the little levers to relieve pressure). Get an OEM one from the Dealer, assuming the radiator is stock or OEM replacement. Fluidyne radiators work best with Fluidyne rad caps, etc.. If that doesn't work, there are probably other problems with your cooling system.
Old 02-20-2009, 04:39 AM   #15
spudz29212MKIII
Oh I see. I did not know that, the car came with one when I bought it. Appreciate the help.
Zach
Old 02-20-2009, 11:06 PM   #16
Bill UK
AEM EMS
Bill UK's Avatar
I have one of those pressure release radiator caps, and after a trip to class or home it kinda fizzes out where the release tab meets the metal cap (hard to describe) like someone has a straw blowing bubbles? I bought a new cap yesterday and it still does it. Any clues? Thanks
There are many different rad caps for the Supra, even more if you include the non-Toyota stock rads. Some caps are very similar in overall size but vary in depth. I made a few drawings of the two different types I have owned with the Toyota part #`s. Ignore the words Halfords and Nissens they only apply to the UK. Just look at the dimensions and the Toyota part #`s. You may have the wrong rad cap ?
Old 02-27-2009, 12:50 AM   #17
sd88supra
Question where does this hose go?
Ok, so I finally got that heater hose I needed. But now I don't know where the bottom hose in the picture goes into. The one on the top obviously goes into the firewall, but I cant see where the one below it goes into, and it doesn't show in the diagram I got from the dealer. I think its just to bypass (because I don't ever remember it going anywhere on the top), but I just want to make sure.
Old 02-27-2009, 06:43 PM   #18
Bill UK
AEM EMS
Bill UK's Avatar
Does this help ? This is a left-hand drive Supra as in the US.
Old 02-27-2009, 08:22 PM   #19
Bill UK
AEM EMS
Bill UK's Avatar
Originally Posted by sd88supra View Post
I can't get the html to work (how do you post pics?), so here's the link.
Old 02-28-2009, 02:39 AM   #20
sd88supra
The upper hose thats plugged with a spark plug is the heater hose on the left side of the diagram (into the firewall). The lower hose (also plugged) is what I don't know about. It's some sort of bypass hose, but where does that plugged end go to?
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
Heater Core Outlet Hose - need help xTomKx MKIII Supra 6 11-21-2007 04:59 PM
Heater By-Passing...Your Thoughts mrnickleye Non-Generation Specific Questions 2 05-03-2006 03:06 PM
