Old 07-18-2005, 04:32 AM   #1
Team_S.O.S_89_Supra
Team_S.O.S_89_Supra is on a distinguished road
Hey guys my supra does a wierd bubbleing noise under the dash as I accelerate, does anybody know what that is?
Team_S.O.S_89_Supra is offline   Reply With Quote
Old 07-18-2005, 11:09 AM   #2
your cooling system is low or there is air trapped in the system . this is a sign of a blown head gasket,however you may just be low on fluid . top it off . if this is the first time . if it continues you most likely have a problem
is this car a turbo ?
Old 07-18-2005, 05:32 PM   #3
Team_S.O.S_89_Supra
Its a non turbo, but im gathering my parts to convert it into a turbo. I dont know much about these cars, but if my cooling system is low what should I buy and where do I put it?
Old 07-18-2005, 08:41 PM   #4
anti-freeze
into the radiator
stock toyota anti-freeze is red
Old 07-19-2005, 10:23 AM   #5
MikeMcSomething
MikeMcSomething is on a distinguished road
You can actually pull off a few caps and park your car on an incline to get the air out of your system. It sounds ghetto but it works.
MikeMcSomething is offline   Reply With Quote
Old 07-19-2005, 10:39 AM   #6
yeps
burping the system
take it to the nearest hill or jack it up
take the cap off (engine cold)
start the car and make sure your heater is on max fan speed and heat
when the thermostat opens you will notice bubbles starting to come out of the radiator
once bubbles have stopped and the radiator is topped up with water to full... put cap back on, let car down and away ya go
does your heater work?
Old 07-19-2005, 04:28 PM   #7
Supra GuestTeam_S.O.S_89_Supra
Guest
Posts: n/a
It was working, but once I did my radiator flush, I might have done something wrong, and my a/c and heater stoped working.
Old 07-20-2005, 01:03 AM   #8
Team_S.O.S_89_Supra
Do I need to jack it up from the front or from the rear?
Old 07-20-2005, 01:49 AM   #9
front
so that the radiator is the highest point of the engine
Old 07-20-2005, 02:12 AM   #10
Team_S.O.S_89_Supra
Thankz,
Weird noise from rear trevor510 MKIII Supra 2 02-23-2008 08:46 PM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
HELP! My engine just started a weird noise... idoke MKIII Supra 12 10-05-2006 05:06 PM
exhaust noise toonen Non-Generation Specific Questions 2 05-19-2006 11:27 AM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
