Old 11-19-2008, 09:54 PM   #1
JDJS45
JDJS45 is on a distinguished road
Default Just changed my spark plugs...
I replaced all my spark plugs with NGKs and have a few questions, the third one was dripping water when I pulled it out, but my engine runs fine and I dont see any signs of water in the oil, and the fifth one was completely covered in oil when I pulled it out. Just wanted to know if you all think I got a oil leak or what? And what could cause one plug to be covered in water?
JDJS45 is offline   Reply With Quote
Old 11-20-2008, 08:25 AM   #2
CyFi6
http://www.toyota-supra.info/forums/...ark-plugs.html
And for the water... Check your throttle body coolant lines for leakage.
Old 12-17-2008, 07:38 PM   #3
mrnickleye
mrnickleye's Avatar
I by-passed the throttlebody coolant lines years ago. Just use a metal or plastic connector to hook both hoses together. Then get a couple of large vacuum caps and put onto the TB fittings (looks better, and keeps dirt out).
I recommend doing this to everyone. The ONLY reason coolant is run thru the TB is to warm it up sooner for a little more emmisions control. BUT......The cooler the air going into the engine, the better it runs, and more HPs.
Old 12-20-2008, 04:57 AM   #4
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Too true, I remember when you told me to do this a couple years back, havent had a problem since :-)
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
Old 12-23-2008, 04:19 AM   #5
suprabahamut
Which lines are the coolant lines? I have pulled my throttle body off a couple times to change my plugs then my plugs and wires. I only seen 1 coolant line. If you have a diagram or picture Mrnickeye it would be great. Please put it up.
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
