Old 11-04-2008, 08:35 PM   #4
wizeguy707
wizeguy707's Avatar
wizeguy707 is on a distinguished road
Default Need Help
This will be a lil reading, same problem here. I had to have my tranny pulled for some work and a new clutch. The auto shop put it back in. No known problems to me for about three or four days. Then I got out of work one night only to have my battery dead as a door nail. I jumped her, and got home. I left it running a while thinking it might have been a rare chance. killed it and cut it right back on w/ no problem. Came out the next morning to the same thing. So, first thing was replacing the battery since I knew the altenator was good. Went about my marry way. Only to figure out the next day that my problem was still there. I had also gotten some replacement factory speakers installed at which point the guy happened to knock my key assembly to the hatch in where I can't get to it. Figuring this might be the problem I bypassed the alarm system(or tricked it to making it think the door was open, so the alarm wouldn't engage) No such luck. Dead the next time I came out to it. NEXT, I tried making a kill switch for the battery, and ran the switch into the car. I had two cables connected to my positive ( one to the starter, one to everything else). I tried hooking both up seperately with no luck again!!!! I tried hooking them up together to the switch which bit me in the ass( too much voltage fried the switch). So, now I'm to the point I'm going to pull my hair out!!!! Any clues??? I just can't get ANY battery to hold a charge in this car even after cutting the power in both directions. I had read about a piece attached to the back of the altenator that regulates voltage...could this be the problem???
wizeguy707 is offline   Reply With Quote
Alarm System mrnickleye MKIII FAQ 1 07-20-2010 04:08 AM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
How to quickly test starter CyFi6 MKIII Supra 4 11-30-2007 01:57 AM
Car alarm/ car starter bigal0043 Car Audio and Alarms 7 10-22-2005 02:10 PM
