Old 08-10-2008, 05:34 PM   #1
Jet Krosswind
Jet Krosswind is on a distinguished road
Default Transmission will not downshift
Hey everyone, I've been having a problem with my Supra with it refusing to downshift when the pedal is down to the floor. In my repair manual it says it is the kickdown cable, but offers no help on fixing it. Any ideas?
87 Supra NA
Jet Krosswind is offline   Reply With Quote
Old 08-11-2008, 04:27 AM   #2
MK3PIMP
MK3PIMP's Avatar
MK3PIMP is on a distinguished road
Get Another Tran It Should Only Be Like 100 Bucks
MK3PIMP is offline   Reply With Quote
Old 08-11-2008, 07:26 AM   #3
btwilson86
Super Moderator
btwilson86's Avatar
Your tranny kickdown cable should be relatively easy to adjust. In case you don't know what the cable is, it's the one that goes up to the throttle linkage from down below the car. When this cable is pulled completely, you should hear a "click" sound from the tranny. If the cable does not get extended to this point when you put the pedal to the floor, then you will need to adjust it.
If it's just slightly off you should be able to adjust the nuts on the cable enough to move it a little forward or back, whichever your car needs. Also, make sure that the bracket that holds the cable is at the proper angle, as this will throw it out of adjustment as well.
You may also want to verify that your TPS is adjusted within specs per the TSRM.
What I have stated may not be the correct way to fix it, but this is what I did when my tranny would not downshift when I would step on it.
Old 08-12-2008, 06:16 AM   #4
Jet Krosswind
thanks for the help!
Old 08-22-2008, 05:49 PM   #5
cme_drft
cme_drft's Avatar
cme_drft is on a distinguished road
Mine was doing that when i first bought it. I replaced the little yellow tranny computer box behind the pass side kick panel. Made it good as new.
87 N/A R154 94 BMW 325i 4 SaLe
84 L-type RIP 08 Jetta Wolfsburg
cme_drft is offline   Reply With Quote
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Blown transmission 1985Supra MKII Supra 2 01-31-2007 07:56 AM
Transmission WiseAssJester MKIII Supra 4 09-26-2005 05:50 AM
