Old 07-23-2008, 08:13 AM   #1
skatecboy45
skatecboy45 is on a distinguished road
Question is there something wrong with my tranny?
It seems kind of difficult to put into gear/shift... is it just me not being used to it (I have been driving my girlfriends 86' celica), or is there something wrong???
Is it just me not being used to the wierd shifter, or is my transmission messed up. The owner before me told me that they put in a new stage 2 clutch not to long ago.
skatecboy45 is offline   Reply With Quote
Old 07-23-2008, 10:26 AM   #2
mkiiisupra
you could start with checking the tranny fluid to see how bad it is.... Then drop the pan and see how much metal is in there on the magnets.
1990 Toyota Supra Turbo A/T
Old 07-23-2008, 07:24 PM   #3
CyFi6
Clutch is the first thing i would check. Bleed the system. How far up on the pedal travel does the clutch begin to engage?
Old 07-23-2008, 08:55 PM   #4
skatecboy45
How do I check the transmission fluid on it, kuz im not really sure how to do it on a manual transmission.
Old 07-23-2008, 08:55 PM   #5
skatecboy45
How do I check the transmission fluid on it, kuz im not really sure how to do it on a manual transmission. Also the clutch is new.
Old 07-23-2008, 09:13 PM   #6
CyFi6
I am not talking about the clutch being new or not, it has to be in the proper adjustment and the fluid line, like a brake line, must be completely free of air, so you need to bleed it first to make sure its free of all air.
To check manual transmission fluid you need the car to be level, and you need to remove the fill plug on the transmission, the fluid level should be even with the bottom of the fill hole.
Old 07-24-2008, 12:51 AM   #7
skatecboy45
okay, how do I check if the clutch is adjusted right, and I have to bleed the transmission fluid?
Old 07-24-2008, 12:56 AM   #8
CyFi6
not quite. You need to first bleed the clutch line fluid, it is totally separate from the transmission fluid. It is the fluid link between your pedal and the actual clutch.
When you are letting off the clutch, where does it begin to engage? Middle of the pedal travel? Closer to the floor? Closer to the top? This can help dtermine the adjustment.
MK3 TSRM On-Line
That is the clutch bleeding procedure.
Old 05-04-2011, 04:28 AM   #9
ochowdero
resurrection...
my pedal engages half way..
how do i adjust the free play?
and the spring over powers the pedal.. meening when i adjust it to be level it just pops it to the floor
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Tranny ? Need Info! SilverBullet05 Non-Generation Specific Questions 0 07-07-2008 09:45 PM
Auto Tranny Issues? jbjorndal MKIII Supra 3 03-14-2008 09:31 AM
Having trouble getting motor separated from tranny... shawn87gta MKIII Supra 15 05-08-2006 05:16 AM
