Old 07-14-2008, 12:32 AM   #1
carodz
carodz is on a distinguished road
Default Broken trip odometer?
I've got a 1992 Supra, and yesterday I noticed the trip odometer seems to have stopped working. The odometer and speedometer are working fine, but I noticed the trip odometer froze at the 100 mile mark. I use this to keep track of how much gas I've used, as my gas gauge is faulty (except for the gas light). If anybody can please suggest a fix, I would greatly appreciate it.
carodz is offline   Reply With Quote
Old 07-14-2008, 01:59 AM   #2
mkiiisupra
mine froze up once i just hit the button to restart it and it started going again. The last number on it sorta came off track a little bit keeping it from moving.
1990 Toyota Supra Turbo A/T
Old 07-14-2008, 02:02 AM   #3
carodz
I hit the reset button on it once and after it reset, I went about 1.9 miles before it froze again. Next trip I reset it again but this time it hasn't moved from 0, even though I logged about 5 miles onto the regular odometer.
Old 07-14-2008, 02:05 AM   #4
supramacist
supramacist's Avatar
These cables aren't really designed for 15+ years of use.
Just break out the tsrm and locate it and remove it and order a new one from your local dealership.
Once you replace it..., it should be as good as new.
Mine hasn't worked since I bought the car and it's never been an issue.
With gas prices climbing such as they are I can see where someone would want one that works.
Once you have a new cable, this should be an easy fix.
Old 07-14-2008, 02:08 AM   #5
carodz
Hopefully so, thanks for the suggestion. I'll look into getting a new cable and replacing the old one soon.
Old 07-14-2008, 03:18 AM   #6
CyFi6
Why would a new cable fix this problem? His speedo cable is obviously working fine if both his speedometer and odometer are working
Old 07-14-2008, 11:56 AM   #7
Canuckrz
Canuckrz's Avatar
Canuckrz is on a distinguished road
Just a suggestion but you might want to fix the gas gauge while you're in there aswell.
Canuckrz is offline   Reply With Quote
Broken Thermo Bolt scruffboy MKIII Supra 17 10-08-2010 01:03 AM
hatchback latch broken burn-one Exterior , Interior, and Detailing 0 07-17-2007 06:22 PM
1991 Supra - Broken Front License Plate Screw unkymurch Non-Generation Specific Questions 1 01-08-2007 02:15 PM
Broken Bolt scruffboy Non-Generation Specific Questions 6 10-31-2006 01:33 PM
Broken BOV Sharaz508 MKIII Supra 7 06-10-2006 05:04 PM
