Old 06-26-2008, 01:51 AM   #1
Chambers
Chambers's Avatar
Question Power Steering Pump and Fluid
Hi all, my power steering pump is starting to take a dump, it has destroyed three belts in the past four months and its now making a quite undesirable knocking sound. So I was wondering where should I look for a new pump, is the dealership my best bet?
Since I'm planning to get a power steering pump I will also fix the current leak, since it wont be leaking I will be able to run a higher quality fluid in it, so what type of fluid do you all recommend?
Thanks.
"Stuck in the 80's"
Old 06-26-2008, 01:57 AM   #2
robertsws
robertsws's Avatar
robertsws is on a distinguished road
i just replaced my power steering pump last week and i got mine from Advance Auto for $100 and i had it the next day.
oh there is a $30 core charge of course
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 06-26-2008, 02:22 AM   #3
supramacist
supramacist's Avatar
I went through 3 pstumps from advanced.
1 trip to O'rielly's and no more issues.
75$ and a warranty.
Old 06-26-2008, 04:52 AM   #4
toneloc87 2
toneloc87 2's Avatar
toneloc87 2 is on a distinguished road
suprasport.com also has rebuilt ones u just have to send in ur core
toneloc87 2 is offline   Reply With Quote
Old 06-26-2008, 01:01 PM   #5
Chambers
Chambers's Avatar
75$ and a warranty.
Wow, I'm not a fan of Advanced anyway, the only thing is that the closest O'rielly's is in Southern Virginia, some 300+ miles away.
I'll check into that, thanks.
Ok, so what kind of fluid are you all running?
"Stuck in the 80's"
Old 06-26-2008, 03:36 PM   #6
supramacist
I run standard ATF. That's all I have ever used. In any of my cars.
JUst get a pump with a warranty. They're easy enough to change if you get one that's crappy. Advanced and autozone are definitley not my 1st stop for parts. But i must say. If they have what I need and I need it that day. I'll stop in..
Old 06-27-2008, 03:24 AM   #7
robertsws
robertsws's Avatar
i'm not crazy about advanced either but it is literally across the street from my house and there are no other auto parts stores around and the nearest toyota dealer is 20 minutes away so it worked for me. besides it was a simple repair and if need be will be a simple repair again.
i must admit though i've never heard of oreilly's
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
ARP bolts w/MHG
power steering pump
Old 06-29-2008, 05:31 AM   #8
CyFi6
you MUST use ATF or you are going to eventually destroy your new pump too. I highly recommend you get the steering system flushed as when the pumps go bad debris can get into the racks small and delicate parts and cause issues.
Old 06-29-2008, 03:59 PM   #9
Chambers
Chambers's Avatar
Yea, I'm going to get a new rack when I replace my pump, it leaks to much to leave that rack in there and risk a new pump getting destroyed from crud getting in there. Thanks for the info.
"Stuck in the 80's"
Power Steering Pump Whining Chambers MKIII Supra 10 01-28-2010 07:19 PM
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
power steering pump blowing fluid carl johansson MKIII Supra 1 11-24-2007 06:34 PM
Power steering pump carfanatic89 MKIII Supra 1 09-15-2007 04:16 AM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
