Old 06-25-2008, 01:59 AM   #11
Chambers
Chambers's Avatar
Would it be possible to get a pic of where your seeing the water coming from? That would help in determining what can be done to fix it.
"Stuck in the 80's"
Old 06-25-2008, 02:01 AM   #12
dcrusupra
dcrusupra's Avatar
The yellow box thats on the drivers side tail light probably went bad. If it was a bad connection your tail lights would work intermittently.
New Rebuild
My CarDomain
Old 06-25-2008, 03:49 AM   #13
supramacist
supramacist's Avatar
You'll have to get a new rear hatch seal from the dealership to fix that leak unless you're an ace with the rtv.
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
light issue kewlcoconut MKIII Supra 5 11-24-2005 04:28 AM
