Old 06-23-2008, 04:41 AM   #1
3.0trd
3.0trd is on a distinguished road
Default power steering problem
I have an 89 N/A manual. I cant steer this thing to save my life. even driving around town, every bump and imperfection is amplified through the steering column, and cornering? forget it! half way through the corner I have both hands on the wheel, praying that the vibration and shaking wont overpower my arms. I replaced the steering rack today, and there was an improvement, on straight and slightly curved roads I can control it, but hard cornering is still out of the question. My ps pump has been flushed twice, makes no noise whatsoever, and turns effortlessly while standing still. Could it still be the pump?
Cometic MHG, ARP studs, H&R lowering springs
3.0trd is offline   Reply With Quote
Old 06-23-2008, 06:50 AM   #2
supraflymk3
supraflymk3 is on a distinguished road
thats sort of what happened to mine but i just needed power steering fluid?
supraflymk3 is offline   Reply With Quote
Old 06-23-2008, 01:20 PM   #3
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
>"My ps pump has been flushed twice, makes no noise whatsoever, and turns effortlessly while standing still. Could it still be the pump?"<
Assuming you mean the pump pulley turns effortlessly and not the front wheels, it sure sounds like the pump is shot. Try a pressure gage test on it. You should get ~1,000 psi when you turn the steering wheel hard left or right.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 06-23-2008, 02:05 PM   #4
3.0trd
actually I did mean the wheels. there are no hard spots or anything when the car is stationary, I can turn from lock to lock with no problems.
Old 06-23-2008, 02:40 PM   #5
dcrusupra
dcrusupra's Avatar
Have you checked the tie rods yet?
New Rebuild
My CarDomain
Old 06-23-2008, 04:03 PM   #6
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation
i'm not sure if you meant that when you corner or turn that the steering is stiff or if you mean that the "vibration" is what makes it diffucult.
Did you check your ball joints? If they are bad then you will get movement between the parts when cornering and eventually they will break off and then you're really screwed.
I would stop thinking pump and look over the entire suspension system.
robertsws is offline   Reply With Quote
Old 06-23-2008, 05:52 PM   #7
supramacist
supramacist's Avatar
If the pump is making noise..., replace it.
It definitley sounds like a suspension issue.
Also the carrier bearing or center support bearing, whichever you call it.
Just give it a check and make sure you aren't getting bad vibes from it.
Old 06-23-2008, 07:55 PM   #8
3.0trd
ok, some more detail. when I first got the new steering rack in, I took it for a test drive on a smooth road with some decent corners. I felt very small ammouts of vibration, but no problems with the steering wheel. that night I took it out on an old road outside of town, it has older cement with small bumps and imperfections, any imperfection I hit I almost loose the steering wheel, but if the road is totally smooth, I have almost no problems at all. I guess it really must be in the suspension system...
Old 06-23-2008, 08:23 PM   #9
supramacist
Isn't that what the cats over at supramania told you as well???
Old 06-24-2008, 02:26 AM   #10
3.0trd
yeah, it is, but I wanted a few opinions, hopefully I have the problem solved, my lower ball joints turned out to be junk, didn't realize till I took a prybar to the bottom of the tire and moved it...
Power Steering?!? Boombastic Drifting 5 05-19-2009 04:19 AM
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump carfanatic89 MKIII Supra 1 09-15-2007 04:16 AM
