Old 06-06-2008, 05:06 PM   #1
dj7mge
dj7mge is on a distinguished road
if the headgasket wasnt replaced i would just change all the fluids and drive the car really easy dont rev it high or anything untill you have some $ saved up to replace it. It's a pretty costly job i spent $1,200 and thats with a employee discount working at a toyota delership but i also replaced all the belts gaskets water pump ect.
dj7mge is offline   Reply With Quote
Old 06-06-2008, 06:08 PM   #2
TomFraser
TomFraser is on a distinguished road
Thanks for the opinions... I think I am going to let it be until it breaks... Thanks for the replies and I'll be sure to post pics!
TomFraser is offline   Reply With Quote
Old 06-06-2008, 10:12 PM   #3
7M-ERIK
7M-ERIK is on a distinguished road
Also check the plastic shroud under the fuel tank. Moisture and leaves like to accumulate in between there and may start to rust the tank. Check all the vacuum hoses and coolant hoses (ISC valve) on the intake manifold, most of mine were shot when I got my car.
'89 Turbo 5spd Targa - 3" exhaust, RT Downpipe, Suprasport elbow, big fmic & pipes, Tein HR coilovers, NGK plugs/wires, Lexus AFM, Apexi SAFC, ARP head studs, TurboXS mbc, removed all A/C garbage, elec. fan, rebuilt CT26, mild port matched turbo hot side
7M-ERIK is offline   Reply With Quote
Old 06-07-2008, 12:41 AM   #4
TomFraser
I looked at Cygnus X1 Home Page
to figure out what you need to do in order to get to the spark plugs, however this is for a turbo... can someone list steps for an N/A?
Thanks to everyone for help
Old 06-07-2008, 04:40 AM   #5
CyFi6
you need to remove quite a bit of stuff. The throttle body, brackets, throttle linkage, y pipe and brackets. Then they are in plain sight. Dont expect to be in and out of there super quick especially if its your first time taking it apart. Good luck!
Old 06-09-2008, 05:12 AM   #6
burton51m
burton51m's Avatar
I like the interior on that car. Espicially the leather seats and the color of them.
Old 06-09-2008, 06:21 PM   #7
TomFraser
i'll post some pics when I get a chance
buying a supra docvtak MKIV Supra 6 11-16-2005 01:29 PM
1993 Supra Sport Roof buying Question SupraDank420 Non-Generation Specific Questions 1 06-07-2005 01:51 AM
