Old 05-26-2008, 01:13 PM   #1
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation smoke, missfire & code 51
I've got a 91 turbo i just bought with 93,000 miles on it. the last owner installed a 3" exhaust, k&n air intake, upgraded blow off valve, and a SAFC 2.
since i got it i changed the spark plugs, TPS, cleaned, inspected and checked the TB, O2 sensor, ICV, and all vacuum lines both at idle and under load.
My problem(s) is that though it is running much better, I've got white smoke on deceleration (BHG maybe), a steady missfire around 4000 RPM until warmed up then it's not nearly as bad, a code 51 when i mash it or when i'm running the A/C then it's a steady 51.
Also if i adjust the SAFC 2 down to 22 on the LO and 14 on the HI i've got no steady missfire (just an occasional missfire and backfire when getting on it) and plenty of power, but it smokes more and stinks plenty when i do that.
What am I missing? I just can't figure it out. I'm thinking maybe timing, it also has a new timing belt so maybe it was timed wrong.
robertsws is offline   Reply With Quote
Old 05-26-2008, 02:52 PM   #2
supramacist
supramacist's Avatar
MK3 TSRM On-Line
It's a few different things Robert.
This is your new bible.
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
White Smoke Drag0na5h MKIII Supra 1 04-25-2006 06:36 AM
Oil n smoke from turbo wolfen Non-Generation Specific Questions 0 10-30-2005 12:27 AM
