#1 |
I have an '87 mk3 turbo with a new (As of January) Japan-amoter. I recently was having over heating probs and blew the radiator. (A crack in the fill spout.) So I put on a new brass, all metal, radiator and water pump. The problem now is that it won't return the water to the radiator from the overflow. So I am still losing water.
I noticed extreme amounts of Leak seal in the last radiator. I attempted to flush the engine prior to replacement. There seams to be no clog in the return lines and I can blow the water back into the radiator when applying pressure backwards through the overflow. (With my mouth) The pressure is strong when hot and no leaks are apparent. I find no oil in the water or water in the oil. The cap that came with the radiator is a 16 pounder. The car exceeds stock specs for speed and power, 0-60 etc....so I know the motor is strong. The turbo is up to about 12psi. Everything is strong. Frankly, I'm stumped. I just want it reliable so I can get on with more speed, power and handling related issues. Oh, and the water light is continuously on. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Where the h--- is the water going??? | illusive38 | Non-Generation Specific Questions | 1 | 05-27-2008 03:23 AM |
| Where the h--- is the water going??? | illusive38 | Non-Generation Specific Questions | 0 | 05-26-2008 09:27 AM |
| Bad Water Pump? | scruffboy | Non-Generation Specific Questions | 10 | 11-26-2006 04:37 PM |
| WAter not going back to raditor from recovery tank Help | Jeff_5_7 | MKIII Supra | 12 | 09-15-2006 03:49 AM |
| pushing water out radiator overflow | mdrury916 | MKIII Supra | 0 | 03-31-2005 03:17 AM |
