Old 04-30-2008, 01:47 AM   #11
mustangtw5901
mustangtw5901 is on a distinguished road
Yes, I do have code 12 stored. I was able to check for codes after I got the problem with the ign 7.5amp fuse worked out and was able to get the computer back online. Thats another reason I wanted to start at the cam sensor first.
mustangtw5901 is offline   Reply With Quote
Old 04-30-2008, 05:01 AM   #12
supramacist
supramacist's Avatar
Talking
Exactly.
We should give you one of them fancy sm badges.
you could be..
toyota-supra.info/specialist tech to advanced product research and developement all things 7m series oil and lubricant code 51 fix'n fire in the
hole havin toyota-supra.info/ specialist badge.
I"m glad your back man
Makes me want to sing..., why do birds.
suddenly appear. Every, time. You draw near;
Need I go on
Old 04-30-2008, 05:15 AM   #13
why do birds.
We drive Supras... hello? Birdcage? But yeah, in my case the bird's plenty happy where he lives and the rest are jealous.
Old 04-30-2008, 05:40 AM   #14
supramacist
???huh?????
Old 04-30-2008, 06:23 PM   #15
mustangtw5901
Supra is back running again, after I put in the new cam sensor she started right up. Its running a little rough, but its been sitting for a year and still needs a few of the bugs worked out. I would still be chasing my tail without this forum. I would like to thank cre and all others who helped me out.
Old 04-30-2008, 07:23 PM   #16
The rough running could be due to old gas if it's been sitting in the tank the whole time. Some recommend adding a can of "Heat" or you can just top it off and run it out.
Old 04-30-2008, 07:36 PM   #17
mustangtw5901
Yea, thats what I figured, the gas is pretty old. I will probably put an additive and top it off with fresh 93.
Old 04-30-2008, 07:48 PM   #18
If you've got a half tank or less just fill it up with 87 octane and just push it too hard. Forget the additives.... at least that's my advice.
EDIT: Actually if you have a 1/4 tank or more go a head and fill it up with 87, if you've 3/4 of a tank top it off with 85. If you do put in an additive do NOT use anything which increase the octane... you need something that's easier to burn not harder.
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
