Old 10-20-2013, 12:45 PM   #11
Busted Knuckles
Busted Knuckles's Avatar
The A/C, installed or removed, will not prevent the car from starting. And, you don't need to cap the WIRES, you need to cap the evaporator lines running through the fire wall.
Have you tried to dis-arm the alarm yet? Lock then unlock the car from the passenger side, then see if it starts. The arm/dis-arm switch is on the door lock cylinders. The driver's side wears out or fails faster than the passenger side due to use. If that doesn't work, you'll need to trace the wires from the starter back to the relay. The alarm on the Supra's ungrounds the relay when the alarm is triggered. Resetting the alarm with the door lock usually resets the alarm and allows the car to start.
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Fuse Removal + Nice Supra Pic jdbones Non-Generation Specific Questions 0 01-28-2008 01:01 AM
BOV Pros and Cons collink MKIII Supra 3 01-19-2008 02:51 AM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
