Old 04-22-2008, 04:02 AM   #11
91na
91na is on a distinguished road
OKAY IM ON THE BOAT FOR ALL THE ABOVE!!!!!!
I live in missouri and actually found a lady in grain valley which is about 20 min east of where I live and she just had her supra ovehauled cause it spit out coolant from overflow bottle one morning in her parking lot where she worked. She told me she had the car towed to a friend and he installed a jdm engine into it. I found her on craigslist. I called her about her motor and asked every question I could think of. She told me she want ed 200. bucks for the engine so I offered her 100 cash and she took it. So far everything looks good but like CRE said I love surprises. But for 100 dollars I couldnt pass that up at all. So im in the process of tearing it down and ill just pull the other one and use what I need and have fun with the rest. Im game for whatever. Again I just need to find some interior panels.
91na is offline   Reply With Quote
Old 04-22-2008, 04:40 AM   #12
^^^ And THAT ladies is how you do it!
Provided you actually have a garage to build an engine in... my wife would kill me if I tried to work on one in the living room.
Old 04-22-2008, 05:28 AM   #13
supramacist
supramacist's Avatar
Yes Sir.
Score of the year. That's as close as you're going to get to a barn find these days.
Now yank out the entire engine piece by piece and drag a$$ to the machine shop and spare no expense. Valve job, port and polish. The entire lot of it.
You want arp studs. NOT bolts. STUDS. You need to know how much metal is removed so you can get the math done for the gasket thickness you require. Performance Parts Aftermarket and Racing Ext. 103. Speak To Dave. Tell him Mike sent you and He'll set you up and he won't brake it off in you.
You want an HKS stopper Metal Head Gasket or mhg. You may as well have the block decked as well. I'll stop here before your brain melts but this is just off the top of my head. Timing belt. Coolant hoses. Tube of molly.
Get all of your parts assembled and together. Before you even start.
Upper engine gasket kits do not come with every gasket you will need but they have everything you need to put the head on. Including injector grommets. Big Plus right there.
Cut no corners and whip the horses eyes. Ride the snake. To the ancient lake.
Old 04-22-2008, 12:29 PM   #14
91na
Your right cre if my wife saw that I was building an engine in my living room she'd have my A$$$ in heartbeat. We cant build them anymore like we did when we were single. I work for suzuki so I have plenty of room to work. I appreciate all the help fellas. This is going to be a very fun project. I always wanted to build a nasty turbo motor in a rear wheel drive car but im just not into the v8s like I used to be.
Old 05-07-2008, 04:40 AM   #15
azerty
azerty's Avatar
azerty is on a distinguished road
Guys, are you trying to scary me?
Let s take it one step at a time.
So, assuming it is rod knock, one should replace the damaged one, but if there would be better changing all of them, right?
Woludn t this be sufficient?
One should change the HG if gone this far?
What else?
What else is a MUST, and what would be a good ideea without being a must?
I ask this to make a starting list, to know if it is just the rod knocking, and everithing else is ok (a very small possibility) what I would have to buy.
The surprises the came along the way... It will be the bonus
Thanks
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Old 05-07-2008, 04:57 AM   #16
supramacist
If you think you have rod knock.
Then you probably do. If you don't, you still have serious issues.
Part it out or rebuild it. Entirely. Buy a different engine and rebuild it.
There is no minimal fix for what you probably have.
UNLESS: You locate the knocking and where it's coming from and verify that it's not rod knock.
It could be piston slap...., which "maybe"...., you can get buy with 1 new one but I doubt it. I don't see a 0 mile piston fitting well into a 15 + year old cylinder and having an extended life expectantcy.
Without a complete rebuild. You can monkey with the top end and make things happen.
But the bottom is the factory. Any issue there is not a good one.
please help engine knocking red_armie_soviet MKIII Supra 1 09-30-2007 01:28 AM
engine knocking red_armie_soviet Non-Generation Specific Questions 1 09-28-2007 10:06 PM
Hard Engine Knocking 86SupraMan MKIII Supra 10 09-14-2007 05:39 AM
funny knocking sound on 7mge Jeff_5_7 MKIII Supra 11 09-09-2007 01:22 AM
knocking block, want to build solid bottom, what should i use alcbarrios MKIII Supra 1 04-14-2006 04:16 AM
