Old 04-13-2008, 09:33 PM   #1
supraman8188
supraman8188's Avatar
supraman8188 is on a distinguished road
Unhappy 88 N/A Manual, No Spark!
I have an 88 N/A manual. It started running rough, then died on the road and will only turn over, not getting any spark from the coil, but the coil is new. Is there something common I should know about? Isn't the coil supposed to get spark before the distributor? STUMPED!
supraman8188 is offline   Reply With Quote
Old 04-14-2008, 12:36 AM   #2
The coil is triggered by the igniter which is controlled by the ECU. The ECU knows when to fire based on signals from the distributor's cam position sensor.
Check the wiring to those three components and test them per the TSRM. It's possible it's the igniter.
Also check to make sure the block is well grounded. From the factory the small ground line on the exhaust side may have been sufficient, but as the wire ages it goes bad fast.
MK3 TSRM On-Line
Old 06-27-2010, 05:56 PM   #3
supraman8188
Smile 88 N/A Manual, No Spark!
Hey thanks cre..sry it's been so long, but I just did get back online(regularly). I actually turned out that my timing belt shredded. It sold my 88 n/a to a guy I work with about a year ago and is still running hard at 230k go supe supe yay
Old 06-28-2010, 04:25 PM   #4
Grandavi
Grandavi's Avatar
I remember the first time that happened to me.. lol. It was a Dodge Aries K-car. Stopped dead for no reason.. and after testing the electronics throughout for 3 days, pulled the front of the motor off and saw that the timing belt has spun out the teeth right at the crank. The other teeth were all there.. it just popped them off at the bottom end..
not sure why.. but it confused me for quite a while.. lol.
Old 06-30-2010, 03:25 AM   #5
batmmannn
batmmannn's Avatar
Default No Spark
That very same thing happened to mine but I did have spark. Mine was still turning the cams but it had jumped out of time. I take it yours was not spinning the top end?
Old 06-30-2010, 03:38 AM   #6
Grandavi
Grandavi's Avatar
My Kcar wasnt turning at the top end. Dont know about the OPS. : )
If the belt breaks, its far easier to identify. Mind.. you I check the belt now before looking at the ECUs
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
What is involved (all parts, labor, price) in auto to manual swap??? the t3d MKIII Supra 1 01-18-2007 03:01 AM
