Old 02-18-2008, 05:33 AM   #1
Rahnter
Rahnter is on a distinguished road
Default Need help with coolant leak near vsv(?)
Please bear with my ignorance in terminology. But I found a website that was linked in another post that shows the part that needs to be replaced toyota Supra pictures heater issue If you look at the second photo from the top, it is the piece that has the arrow draw on it, with an inlet outlet for the coolant. Basically, the inlet piece snapped. I wanted to know what this piece is called and I can bypass it until I can find a replacement. Any help is appreciated. Thanks
Rahnter is offline   Reply With Quote
Old 02-18-2008, 02:23 PM   #2
Pretaco
Pretaco is on a distinguished road
Its called the heater coolant control valve or something close to that. (water control valve for the heater). You can bypass it, but your heater will always be hot which will hurt your a/c efficiency. Here is the link for the part number: (left hand drive).
Electronics Parts Catalog
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 02-18-2008, 06:01 PM   #3
Rahnter
I think I may just bypass it for the time being. As far as a/c efficiency, that shouldn't be a problem, as my a/c doesn't work. But is there any chance it may damage my heater core? Thanks for the help.
Old 02-20-2008, 04:06 AM   #4
mrnickleye
mrnickleye's Avatar
No damage, as the coolant always flows thru the core EXCEPT when the auto temp is set to 65*.
By pass can be done, and then forget about it and move on to other more important repairs.
Old 02-20-2008, 04:59 AM   #5
Rahnter
Ok. Thank you both for the help.
Old 02-21-2008, 01:17 AM   #6
ddmcse
ddmcse's Avatar
Cool heater value
it's my picture
glad it was of help
wish google hadn't banned me , i'd be counting the clicks !
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Coolant Leak zcoolboard MKIII Supra 7 03-30-2009 06:54 PM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
Strange Coolant Leak Help PLZ!! 87TurboProject MKIII Supra 11 03-14-2006 03:14 AM
MKIII coolant leak HELP sportriderseattle Non-Generation Specific Questions 2 12-21-2005 06:12 AM
