Old 06-21-2005, 06:20 AM   #2
mrnickleye
mrnickleye's Avatar
Is it a light tapping sound? = valve adjust......
Piston slapping the walls ???
Rod knocks, (bearings) sometimes can be made to sound up by lightly playing with the throttle. Barely increase and decrease the rpm a little bit, if it gives a rattle sound, it could be a rod bearing. Pull spark plug wires, one at a time, and ground them. If the sound stops on a certain cylinder, its that one bad.
engine knocking red_armie_soviet Non-Generation Specific Questions 1 09-28-2007 10:06 PM
Potentially buying 1987 Supra Turbo with knocking noise saturnvii7 MKIII Supra 3 04-24-2007 05:59 PM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
HELP! My engine just started a weird noise... idoke MKIII Supra 12 10-05-2006 05:06 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
