Old 01-14-2008, 04:29 AM   #11
CyFi6
ive got a leak but im not ready to spend that kind of money on a hose. Anyone know if you can put together a hose using those hoses/fittings from summit racing for a little cheaper?
Old 01-14-2008, 04:40 AM   #12
Irish_Mechanic
Irish_Mechanic is on a distinguished road
Default not psychic, but i've got an answer for everything...
Originally Posted by xTomKx View Post
Sorry there buddy the pinhole was in the rubber part of the hose.
well, as some of the rednecks i've worked with say, "J.B. Weld is the new duct tape!"
Irish_Mechanic is offline   Reply With Quote
Old 01-14-2008, 02:00 PM   #13
xTomKx
xTomKx is on a distinguished road
Originally Posted by Chambers View Post
Wouldn't happen to have any pics of the process? Because that would make a good how to write up. Good to hear you got it together though!
I didn't take any pictures but it is very straight forward. To remove the steering rack I had to remove four bolts. On the passenger side they are on top of the subframe. On the driver's side one bolt is on top of the subframe and one is accessed through a hole in the subframe from the bottom. Then I had a buddy of mine pry up the steering rack with a prybar while I routed the line in it's place.
xTomKx is offline   Reply With Quote
Old 01-14-2008, 02:50 PM   #14
Pretaco
You can take the high pressure hose out, and take it to a hydrolic hose company who can rebuild the rubber portion for $20-30 ususally. I've done that to quite a few p.s. hoses. Its really not that much cheaper, but since you are using the old metal fittings, they will work better.
maybe.
Ray.
Currently Running Good
Old 01-14-2008, 07:50 PM   #15
Irish_Mechanic
how much for the turbo ecu you have for sale?
Old 01-15-2008, 06:34 AM   #16
ethan12510
ethan12510 is on a distinguished road
try ur local autozone they sell a p/s pressure hose for 60 bucks
ethan12510 is offline   Reply With Quote
Pressure Hose on Power Steering, first Supra and first post here. ddouglas77 MKIII Supra 4 12-01-2008 04:15 AM
Picture? Power Steering pressure hose ptomko MKIII Supra 4 10-08-2008 02:19 PM
Power Steering Return Hose. teedoff00 MKIII Supra 4 11-28-2007 07:53 PM
