Old 01-03-2008, 08:17 PM   #1
Chambers
Chambers's Avatar
Default When is The Best Time to "Burp" The Car?
Hi all, I changed the rat fluid a few months ago and I got some air in the system giving me cold heat while driving. I have tried to bleed out the system a few times but I still have some air some where in the it.
My question is when is the best time to "burp" the car, when the engine is cold or warm? By the way, I know a warm rat will spray fluid when opened.
Also how much of an incline would be ideal? Thanks!
"Stuck in the 80's"
Old 01-03-2008, 08:45 PM   #2
btwilson86
Super Moderator
btwilson86's Avatar
From what I've read and done on other cars is to jack it up to about 35-45 degree angle (if possible; hills help with this). Pop the radiator cap off, turn the car on and the heater on full blast, and let it run for a looooooooooooooooooooong time. You should be seeing bubbles coming up at the radiator cap, and as long as your not revving the motor or anything, your coolant loss should be minimal. Just bring some premixed coolant with you because your coolant level will slowly drop as the air escapes.
I've never done this on a Supra cuz mine hasn't worked long enough for me to be able to, but it should be as I described. The greater the angle the better because of the height of the heater core versus the top of the radiator cap.
Old 01-03-2008, 11:31 PM   #3
Chambers
Chambers's Avatar
Ok, thanks. That helps, I'll do that tomorrow when I replace the speedo cable.
"Stuck in the 80's"
Old 01-04-2008, 03:40 AM   #4
suprakid91
suprakid91's Avatar
suprakid91 is on a distinguished road
i have to burp it too. thanks for the post. and how much did your speedo cable cost you. how long was it and did you also get a new housing for it cuz mine broke too and i cant get the old one out.
91' 7m-gte, sold
suprakid91 is offline   Reply With Quote
Old 01-05-2008, 05:45 AM   #5
CyFi6
even with the car on a slope i couldnt get the air out of the heater core completely, still got the waterfall noise. i found a better way to do it. get some a pair of vice grips and clamp off the line going to the heater control valve on the top. remove the heater core line comming from the bottom of the valve and quickly sumberge it in a bottle about half full of water or coolant mix, water should be fine. make sure the end of the hose is completely under water. Now, while holding the bottle, grab the upper radiator hose and squeeze it as hard as you can as fast as you can, its ok if water splashes out of the bottle, then hold it like that, wait for all the bubbles to go to the top. SLOWLY let go of the upper radiator hose and do it again and again until no more air puffs out when you squeeze. Now what i do is remove the radiator cap and remove the vise grip and reattatche the hose as quickly as possible, all those 3 things as fast as you can, i remove teh cap and release the vice grip in effort to let coolant flow through the heater valve and get the air out, then the displaced coolant can be filled into the radiator. THis worked perfect for me and no more waterfall/trickling water noise in the morning
Haha.....Read these Emails about SUPRAS FOR SALE Metalluthier Non-Generation Specific Questions 54 04-25-2011 11:51 PM
Supra time? furia MKIII Supra 11 08-28-2007 01:19 AM
One more time, my air removal method. Monkey Non-Generation Specific Questions 2 04-20-2007 02:09 AM
0-60 time f00g00 MKIII Supra 16 08-09-2005 05:53 PM
