Old 12-05-2007, 11:58 PM   #1
jcgrant4
jcgrant4 is on a distinguished road
Default No spark mystery on 7mgte
I've lost spark on my 88 7mgte and have hit a wall in my diagnostics. I've got 12v at the 3 coil pack connectors and the ignitor, the resistance on the cps connector pins is all good, but no spark. I tried a back up coil pack, no help. The one thing I can't figure out how to test is for the signals the ignitor sends to the coil packs to fire the plugs. Any ideas? TIA
Jim G
jcgrant4 is offline   Reply With Quote
Old 12-06-2007, 10:07 AM   #2
have you tried wiggling the cps plug?
what codes have you got?
Old 12-06-2007, 12:44 PM   #3
jcgrant4
No codes - I haven't had it started since disconnecting the battery to clean the terminals & check the cables. I'm suspicious of the cps plug/wiring after reading the tons of other posts on this topic, so I'll check that out next.
Old 12-06-2007, 09:24 PM   #4
jcgrant4
Okay, cps connector/wires look good, so I decided to check the cps terminals at the ecu. Found 3 plug wasn't seated tight. Now I get spark, but it's weak & intermittent. BTW - the cps did test good at the ecu connector, so now what - ignitor?
Old 12-06-2007, 09:49 PM   #5
the cps wires directly at the cps plug generally naff out
usually a good wiggle will get the car going again
Old 08-19-2009, 03:57 PM   #6
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation
hey I have this problem. did you ever figure it out?
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 08-19-2009, 05:50 PM   #7
shiftysupra
shiftysupra's Avatar
do you have an auto harnesson a manual? if you do make sure your neutral start switch spliced wiring is good. when you try to start it does it try and start or do you hear just a click noise? more info needed buddy.
Old 08-19-2009, 05:51 PM   #8
shiftysupra
oh and you really need to check here before posting...
next time read the bible first...
http://www.cygnusx1.net/Supra/Librar...3/default.aspx
Old 08-19-2009, 05:57 PM   #9
robertsws
robertsws's Avatar
I appreciate the link to the TSRM, been there. I just don't have spark. that's it.
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
ARP bolts w/MHG
power steering pump
Old 08-19-2009, 06:21 PM   #10
shiftysupra
so it tries to start (and turns over) but just doesnt actually start? have you checked your efi fuse?
it may be the cps. like supra girl said try wiggling the plug or if possible try and swap it with someone else to see if it's faulty
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
7mgte swap no spark supra4life1386 MKIII Supra 5 11-27-2008 07:57 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
