Old 11-23-2007, 08:16 PM   #1
carl johansson
carl johansson is on a distinguished road
Default power steering pump blowing fluid
OK Guys,
I will be running an 87 NA supra on a road race course for 8 hours, 2 days in a row. Has anyone had any problems with the powersteering fluid getting foamy and burping out - thereby oiling down the tires as well as the racetrack.
This is a common problem for other cars - and we typicallty deal with iotv by revalving and rebuilding the pump to give lower amounts of boost at higher RPM - but with this high reving motor i can see potential for a bad problem with this issue.
Since I am limitted to 500 bucks - the easiest solution may be to remove the powersteering pump - and run it with no powersteerring - which is typically not a problem on a road course.
Anyone have any experience with this?
Carl Johansson
carl johansson is offline   Reply With Quote
Old 11-24-2007, 06:34 PM   #2
MKIII_rider
MKIII_rider is on a distinguished road
i've been running my 87 supra turbo 5 speed for a while now without power steering. your car should still turn okay when it's moving but it'll take a little more effort. but if your car is sitting still it'll be harder to turn.
MKIII_rider is offline   Reply With Quote
Power Steering Pump Whining Chambers MKIII Supra 10 01-28-2010 07:19 PM
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump carfanatic89 MKIII Supra 1 09-15-2007 04:16 AM
Power steering pump.. 89 turbo. 2JZEFINI-17 MKIII Supra 4 03-13-2007 03:23 AM
