Old 06-12-2005, 06:33 AM   #1
87supraguy
87supraguy is on a distinguished road
just did a tune up on my 87 supra n/a 5 speed and now it idles between 2000 and 2500 rpm's. It ran fine all day untill i left later that night to go to work it started acting up in the parking lot by idline real low. after work it idled low still and than gradually started idlingnhigher and higher. i put new plugs in (bosch platinum 2) new wires, cap, rotor, and valve cover gaskets and gromets( was leaking oil from them) i ran the engine diagnositcs tonight and got 22, 24, 32, and 51. ran this before and nothing ever showed y would they come up now?? I've doubled checked all vaccum lines and electrical connections please help
87supraguy is offline   Reply With Quote
Old 06-12-2005, 12:24 PM   #2
well.. i would reset your ecu for a start... pull out the main & efi fuse for bout 30 seconds
22 = water temp sensor
24 = air intake temp sensor
32 = afm signal
51 = tps
did you unplug all of these sensors when you did your plugs etc?
try this first... and let us know how you get on
Old 06-12-2005, 08:30 PM   #3
87supraguy
Supra girl i unpugged the efi and main fuses and it still does it how do i replace the afm and air intake temp sensor?? are they on or in the intake hoses?
Old 06-13-2005, 12:06 AM   #4
i would say that the sensors are all fine
they only threw a code because you unplugged them with the battery connected
i would take a look at the tps tho.. do a search i've posted a link somewhere to a page to set the tps
Old 06-13-2005, 05:22 AM   #5
87supraguy
supra girl should i disconnect the battery see if that helps? what tps and what does it do? thanks
Old 06-13-2005, 05:27 AM   #6
hangsupra
i just wondering about the mk3 tps... supra girl. can you adjust the mk3 tps. or you cant. cause our mk2 we could adjust the tps. i just wondering is the mk3 n mk2 were the same setup. it sounds like i were crazy but i just wondering.... so please "DONT QUOTE ME ON THIS ONE" anyone...
Old 06-13-2005, 05:48 AM   #7
as said above... there is a link on the forum somewhere on how to set the tps
87supraguy
on the throttlebody there should be a little black round thing on the side of it... this is your tps... make sure the plug is firmly connected
another way to reset the ecu is to disconnect the battery but remember you lose your clock & radio settings
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
annoying high pitch squeal at idle oowee623 MKIII Supra 2 06-04-2007 03:02 AM
'92 7MGTE- high and unstable idle liona MKIII Supra 7 02-04-2007 03:18 AM
High idle nickvash0104 MKIII Supra 21 07-13-2006 05:14 AM
