Old 11-07-2007, 12:59 AM   #1
wingshooter92
wingshooter92 is on a distinguished road
Lightbulb car cuts out at 4000 rpm
ok i ahve replace valve covers and the #3 gaskets and the car is still cutting out at 4 grand is it running out of fuel or is the tourqe converter gone bad anyone please help
wingshooter92 is offline   Reply With Quote
Old 11-07-2007, 02:24 AM   #2
mrnickleye
mrnickleye's Avatar
I doubt the TC has anything to do with the engine cutting out.
Start checking the spark first. Then fuel pressure.
Old 11-07-2007, 02:44 AM   #3
tsupra89
tsupra89's Avatar
tsupra89 is on a distinguished road
i think that you need to def check fuel pressure more then spark what sounds to me like its flooding the cylinder. supras come with a stock fuel pressure regulator and yours might have gone bad and when you are gunning it as i would expect that the fuel pressure regulator is malfunctioning and its causing it to flood the cylinders. hook up a fuel gauge and see the fuel pressure and make shure its around what it should be. the rev it up to 4 grand and see if it increases. thats what i would check first.
tsupra89 is offline   Reply With Quote
Old 11-07-2007, 03:13 PM   #4
mrnickleye
mrnickleye's Avatar
Wink
This not how you test the fuel pressure. Also, it would be impossible to 'flood' the engine with fuel at 4000rpm because of a bad FPR.
"Starve" the engine would be the results.
Start here: http://auto.howstuffworks.com/fuel-injection.htm
Old 11-07-2007, 04:30 PM   #5
tsupra89
tsupra89's Avatar
my bad then. im just putting my best geussing into play.
Old 11-07-2007, 07:42 PM   #6
Supra2NR
Supra2NR's Avatar
Is it a turbo car?
Cuz when I had a boost leak everytime I get boost when rev are around 4400 it'll start to sputter and die down
And I have to rev it up to keep it from dying
Old 11-08-2007, 01:28 AM   #7
wingshooter92
Default ok now what
i changed the fule filter i think i will put in a new fuel pump and mabey that will fix it
Old 11-08-2007, 03:26 AM   #8
mrnickleye
mrnickleye's Avatar
Angry
DO NOT JUST THROW PARTS AT IT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GET IT DIAGNOSED BY A PROFESSIONAL BEFORE YOU DO THAT.
Old 11-08-2007, 03:52 PM   #9
tsupra89
tsupra89's Avatar
if it was me i would do a feul pump and a fuel filter walboro aka weinboro is a good way to go they have a lifetime warrenty for them. and you can never go wrong with putting them in but dont be sad when you put them in and it doesnt fix the problem. but when you got it done youll be happy you replaced them.
Old 11-12-2007, 03:44 AM   #10
jfunez
jfunez's Avatar
lol........................................
Engine cuts out igosaur MKIII Supra 9 02-07-2019 07:09 PM
engine cuts and dies uddinf MKIII Supra 9 09-06-2009 06:56 AM
