Old 06-10-2005, 03:36 AM   #1
mrnickleye
mrnickleye's Avatar
Has anyone out there installed an MSD Ignition Box on their MKiii N/A???
I hooked one up 2 years ago. I had to use an adaptor for the Tach/injectors to function properly. It works by making the plugs fire 15x instead of once on each power stroke. It will insure that ALL the fuel is burned. I could not tell any improvement, but I did see my MPG increase by 4 on long trips (26 mpg).
I removed it after 1 year because the tach needle would jump around occasionally. I emailed back and forth with the manufacturer trying to figure a way to get it solved. No success.
Any comments??
Old 06-10-2005, 12:54 PM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
well i myself haven't had experience but IJ on sm will most likely answer ur post
Pics of my build.
Do a diagnostic first!
Old 06-12-2005, 10:29 PM   #3
pabrosmc
pabrosmc is on a distinguished road
Any comments??
dont put it back
msd is garbage
i put one on a mk3 turbo
and no success eithier
pabrosmc is offline   Reply With Quote
Old 06-13-2005, 08:43 PM   #4
monkihead
SP58GT
monkihead's Avatar
id put one on, but it depends on which model your going to put. last time i checked the dis-4 plus was the one to go with for the turbo models. 6a(6al for rev limiter) for non-turbos. i help my friend install one on his honda and it made a hell of a difference.
monique- better off dead
Old 06-13-2005, 11:02 PM   #5
Guest
Guest
Posts: n/a
Yep....model 6A (no rev limiter). I may try it again, as its still mounted in the car. Someone on another forum said something about grounding any wires that weren't used. I don't knpw about that. What do you think?? The MSD tech line guys did not say to do that.
Old 06-13-2005, 11:04 PM   #6
mrnickleye
mrnickleye's Avatar
Oppsss....last post was mine...forgot to log in.
Old 06-18-2005, 07:23 PM   #7
monkihead
SP58GT
monkihead's Avatar
when installing one, you may not need the use of the ignitor. all you need is a trigger signal to the box for it to fire the spark. its been a while...
Ignition Synchronizer - what is it ??? cgreiner MKIII Supra 4 01-15-2009 08:39 PM
MSD ignition system for MKIII? Boombastic MKIII Supra 1 08-21-2007 03:21 PM
Ignition Ghost motosparky MKIII Supra 3 11-15-2006 03:45 PM
Ignition write up.. midwestmk2 MKII Supra 0 06-11-2006 02:56 AM
Ignition dcrusupra MKIII Supra 5 10-04-2005 09:09 PM
