Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 10-30-2006, 07:47 AM   #31
tellfromchico,ca
tellfromchico,ca's Avatar
tellfromchico,ca is on a distinguished road
u might want to make sure your temperature sending unit is still good or needs cleaned it located on the thermestat housing.
Originally Posted by dcrusupra
I have the problem with the temp gauge, but luckily no problems. While im driving it shoots back and forth. Its either cold or overheating or where it should be. Most of the time it says its really hot. But its still good and driveable. So its just a malfunction with the temp gauge. Not much of a nuisance so i dont worry about it. My gas gauge is like this too. I dont pay attention to the needle but when that little orange light comes on, its definitely time to get gas. Goodluck and hope its not the BHG.
tellfromchico,ca is offline   Reply With Quote
Old 12-09-2006, 12:35 AM   #32
chash360
chash360 is on a distinguished road
Originally Posted by Dejvid1785
I don't have any smoke out of the exhaust or milky oil, but i am losing coolant!! Could that still be thermostat or something else? My temp gauge never stays still it sits up top showing that its over heating but the car isn't over heating and is driveable and suddenly it jumps back down, if anybody knows answer me. Thanx!
The needle going up and down can be a sign of a sticky thermostat, or improperly installed thermostat. The installation direction of the thermostat is often counter intuitive, it opens against the flow, but the housing does not prevent you from installing it backwards.
Gas Bubbles in your cooling system can also cause irractic temp needle behavior, this is usually bad, it does sound like you have an exhaust-to-coolant BHG, if you are losing coolant consistantly. And it will not show in your exaust, other than maybe being slightly more steamy.
The first few things I do to a newly aquired MKIII is a valve job with a new head gasket (I use metal laminated graphite, coated with teflon gaskets, usually from NAPA, and replace all the bolts with ARP, the teflon does a great job dealing with the aluminum head-to-cast iron block shearing that occurs with temp extremes, it actually reseals itself). Second thing to do, convert to all electric fans, it will keep your temp under control better, and give you a little snappier response on the throttle with out the fan drag.
I have driven both a MKII and MKIII from Oregon through the Nevada desert up Mt Rose (8000+ ft) to Lake Tahoe in July, and you will not make it up that grade without electric fans or stopping to cool off.
chash360 is offline   Reply With Quote
Old 12-09-2006, 07:10 PM   #33
Isphius
Isphius's Avatar
http://www.toyota-supra.info/forums/...64&postcount=1
All of these are very good signs too lol. Dam BHG!!!
Old 12-26-2006, 08:33 AM   #34
mookydaspooky
mookydaspooky is on a distinguished road
I have a 88 NA supra, i'm trying to figure out if my thermostat is out or is my head gasket blown? What usually happens or what symptoms there are when your head gasket is blown?
Try to take out the old thermostat and punch out the insides of it and then replace it. Then you will know that it is not your thermostat.
Does your car use up any water? If so, and it probably does, then it could be your head gasket. I blew two head gaskets, on two different engines in the past year. You need to check your distributor!!! That is what caused both of my engines to blow. There are three different modules in the inside of the distributor that you need to check. You can test them in a few minutes, with a meter. I used my old distributor in the new engine I bought, which was a big mistake. I do not want you to make the same one. My car was smoking and burning oil. Also, when I checked the timing on my car, it was fine. But, when I advanced the engine, the timing went off the chart. This was do to two of the modules in the distributor going bad. A new distributor is only $256.00, from Toyota. Let me know if this helped you. David
mookydaspooky is offline   Reply With Quote
Old 01-23-2007, 02:52 AM   #35
Jermalicious
Jermalicious is on a distinguished road
Exclamation Blown Head Gasket
My 87 Supra has a blown head gasket and ive heard about certain head gaskets that help with the tourque spec issue Toyota had back in the day. I would like to know what people would recomend for me to get for a head gasket.
Jermalicious is offline   Reply With Quote
Old 02-06-2007, 02:52 PM   #36
mkIIIdraper
mkIIIdraper's Avatar
mkIIIdraper is on a distinguished road
I am currently in the process of determining weather or not i have the dreadded BHG. the guy that had the car before me said he put a metal head gasket on it, so i'm hoping that it's not that. I have some information though I'd like to share.
The heater core was replaced and the antifreeze that was put in was the orange kind from prestone. i have been putting that in it because it sounded like a good coolant. and the coolant was bubbling over. last night i went to buy some more at the auto parts store and the guy behind the counter almost took my hands off. WOAH he said don't put that in it. It'll gum up. it's specifically for GM vehicles!!!
i have already put two jugs of this in my car and now i'm gonna try to flush my cooling systtem with some anti gunk stuff and replace my thermostat as i suspect that it is gummed up and stuck. hopefully i can fix the problem
hope noone else has put this in their poor supra
88 mkIII, manual, turbo, hks valve management system, non restrictive exhaust, cold air intake, 15lbs, 12.89 @108 mph
mkIIIdraper is offline   Reply With Quote
Old 02-06-2007, 05:13 PM   #37
dcrusupra
dcrusupra's Avatar
The guy behind the parts counter was right. Dexcool is bad for any car that is not GM. They didn't even make Dexcool until 2000. So yes, go for the green stuff or get Toyotas red stuff. Definitely flush the system. Also, ask the previous owner if he got the block surfaced and lapped.
New Rebuild
My CarDomain
Old 02-06-2007, 07:01 PM   #38
mkIIIdraper
cool thanks for the advice i hate the orange stuff!!!
Old 02-12-2007, 07:49 PM   #39
mkIIIdraper
thermostat:replaced
coolant system:flushed
still no heat and still bubbling over
i guess its time to bite the bullet and get a head gasket
anyone have any suggestions...... i dont think i can have the block lapped
but i definately will have the head machined
Old 02-13-2007, 04:51 PM   #40
IHateHacks
IHateHacks's Avatar
Before you start breaking out the wrenches, why don't you run a block test and pressure test the cooling system? For a pressure test you only need to take the radiator cap off, and for a block test you need to take cap off and drain half the fluid in your radiator.
If you don't know what these things are just go to your local auto parts store and tell them you need a "block test kit" or a "Cooling system pressure tester".
HTML code is On
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Blown head gasket? h8z2luze MKIII Supra 30 06-03-2006 03:18 AM
