Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 04-06-2010, 10:41 PM   #1
Busted Knuckles
Busted Knuckles's Avatar
I've had to do this 3 times in a row over 2 days, then another time removing the transmission. My trick was to use a 14mm (or was it 17mm) box end on the nut just above the starter, and use a ratchet with a loooooooong extension to get to the bolt head on the transmission side from underneath. Still a PITA, but it worked.
HTML code is On
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
auto transmission issue 87-POSupra MKIII Supra 2 03-26-2009 05:12 AM
Auto Transmission Swap big_kahuna89 MKIII Supra 1 06-13-2008 11:13 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
