Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 12-01-2004, 09:15 PM   #4
extendor
extendor is on a distinguished road
I ha a gurgling sound in the engine when revving away so I took it to the local shop. I said about needing the system burping and about removing the thermostat and drilling a hole in to ease the problem and they initially agreed.
They split the thermostat housing away and there was no thermostat fitted at all.
They did a HG check and said it was OK. They did not have any thoughts apart from the system needed burping once and for all.
Does anyone have any thoughts.
Thanks
extendor is offline   Reply With Quote
HTML code is On
82 Supra overheating suprahusker MKII Supra 2 10-17-2007 01:59 AM
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
car overheating marc MKIII Supra 11 06-30-2006 05:55 AM
suddenly overheating... how bad? sd88supra MKIII Supra 3 06-21-2006 10:21 AM
Need Help, Overheating Problems MDellboy420 MKIII Supra 9 12-19-2005 06:46 AM
