Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 10-11-2008, 12:10 AM   #32
Tateslikeink
Tateslikeink is on a distinguished road
ALSO!! I found an exhaust leak.. coming from one of the gaskets between the exhaust manifold and the downpipe.. Could that cause this problem?? The mechanic who did my compression test said it was fine.. I just remember the numbers being weird. It was only cranked for 2 seconds on each cylinder. I didn't think that would give u an accurate reading. And the block test came out clean. All i know is that this problem is very annoying and i can't wait to either fix this issue of get rid of the car.
Tateslikeink is offline   Reply With Quote
HTML code is On
82 Supra overheating suprahusker MKII Supra 2 10-17-2007 01:59 AM
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
car overheating marc MKIII Supra 11 06-30-2006 05:55 AM
suddenly overheating... how bad? sd88supra MKIII Supra 3 06-21-2006 10:21 AM
Need Help, Overheating Problems MDellboy420 MKIII Supra 9 12-19-2005 06:46 AM
