Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 02-07-2007, 06:28 AM   #27
mrnickleye
mrnickleye's Avatar
Wink Sealant No Workie
Why, you ask, won't radiator sealer work on the 7M BHG problem.??
Because the "usual" BHG starts out as a tiny hole from a combustion chamber (usually #6 cyl) to a water passage.
The enormous pressure during combustion pushes the gasses 'into' the cooling system. This then builds up too much pressure and causes coolant to eventually over flow into the recovery bottle.
The sealant only works when the coolant is trying to leak 'out of' the cooling system to atmosphere. It plugs the hole.
HTML code is On
82 Supra overheating suprahusker MKII Supra 2 10-17-2007 01:59 AM
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
car overheating marc MKIII Supra 11 06-30-2006 05:55 AM
suddenly overheating... how bad? sd88supra MKIII Supra 3 06-21-2006 10:21 AM
Need Help, Overheating Problems MDellboy420 MKIII Supra 9 12-19-2005 06:46 AM
