Old 04-13-2005, 01:07 AM   #21
hangsupra
sure no problem....because....the 6mgte is usually came in turbo.....in japan....and the 6mge is not turbo....but still have higher compression then the 5mge....because it built into 3.0L not 2.8L like the 5mge....its like the mk3 supra.....the 7mge is non-turbo and the 7mgte is turbo... pretty is the same like the mk3 supra....but just that the US didnt carry the 6mge or 6mgte....because its made in japan and not in US...if you want the 6mge or 6mgte you can still get it from japan tho....
Old 04-13-2005, 09:34 AM   #22
the_fallen
the_fallen is on a distinguished road
don't know what your on about, but from what i've researched, there was no 6mgte. there was a 6mge that came out just before the mk2 supra stopped production. there was also a 5mgte that was built to trial, very few numbers were actually made, and even fewer actually were sold. the 5mgte never made it into full production. these were JDM only.
the_fallen is offline   Reply With Quote
Old 04-13-2005, 05:01 PM   #23
monkihead
monkihead's Avatar
:blink: is that importing it from uranus??
monique- better off dead
Old 04-13-2005, 05:06 PM   #24
hangsupra
Originally posted by the_fallen@Apr 13 2005, 09:34 AM
don't know what your on about, but from what i've researched, there was no 6mgte.* there was a 6mge that came out just before the mk2 supra stopped production.* there was also a 5mgte that was built to trial, very few numbers were actually made, and even fewer actually were sold.* the 5mgte never made it into full production.* these were JDM only.
for what you said is true too but i have this one japanese supra tunner magazine its all about the mk2 n mk3 only.....and there is a 6mgte and also the 5mgte like you said too....you got there soon.....keep research....you got it...
Old 04-13-2005, 05:11 PM   #25
hangsupra
he got 6mgte on his mk2 too see....
this is what the 6mgte look like the 6mgte oil filter are located little more to the right not like our 5mge...because our 5mge is locate like in the middle of the block...but the 6mgte is little more to the right.... the 5mgte oil filter sure located between the piston 3 and 4...and the 6mgte is little bit to the right which is located between the piston 2 and 3.... take a look on it...
this is another 1985 Toyota Celica Supra 6mgte
take a look on it... :P
Old 04-13-2005, 05:42 PM   #26
monkihead
monkihead's Avatar
uh, if you paid attention to the pics, you would have noticed the first engine pic doesnt have a turbo. its probably a 6mge. the others are an aftermarket or custom built turbo kit.
Old 04-13-2005, 05:46 PM   #27
hangsupra
I BELIEVE YOU...THE FIRST PICTURE MAYBE A 6MGE INSTEAD OF 6MGTE......BUT SCRL. DOWN TO SEE THE 6MGTE BLOCK YOU SEE THE DIFF. BETWEEN THE 5MGE N 6MGE THO.... BECAUSE....THE OIL FILTER IS MORE TO THE RIGHT THO....CORRECT ME IF I WRONG AGAIN... HEHE..
Old 04-13-2005, 07:21 PM   #28
monkihead
monkihead's Avatar
Originally posted by hangsupra+Apr 13 2005, 11:46 AM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (hangsupra @ Apr 13 2005, 11:46 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin--monkihead@Apr 13 2005, 05:42 PM
I BELIEVE YOU...THE FIRST PICTURE MAYBE A 6MGE INSTEAD OF 6MGTE......BUT SCRL. DOWN TO SEE THE 6MGTE BLOCK YOU SEE THE DIFF. BETWEEN THE 5MGE N 6MGE THO.... BECAUSE....THE OIL FILTER IS MORE TO THE RIGHT THO....CORRECT ME IF I WRONG AGAIN... HEHE.. [/b][/quote]
dont worry i will correct you. the 5mge and 6mge share the same block and heads. its the bore & stroke that are the difference between a 2.8l to a 3.0l.
Old 04-13-2005, 10:20 PM   #29
hangsupra
Originally posted by monkihead+Apr 13 2005, 07:21 PM--></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (monkihead @ Apr 13 2005, 07:21 PM)</td></tr><tr><td id='QUOTE'>
dont worry i will correct you. the 5mge and 6mge share the same block and heads. its the bore & stroke that are the difference between a 2.8l to a 3.0l. [/b][/quote]
THERE WE GO...YOU GETTING THERE TOO.....
Old 04-13-2005, 11:14 PM   #30
hangsupra
OH I FORGOT ONE THING ABOUT 6MGE OR 6MGTE.....THE 5MGE CAME OR HAVE THE EGR VAL. ON THE CHAMER... BUT THE 6MGE AND THE 6MGTE DID NOT CAME OR HAVE THE EGR VAL. ON THE CHAMBER....
Can my 1982 Supra be saved? CraiginCentral MKII Supra 1 02-06-2009 07:38 AM
