Old 02-11-2006, 02:08 PM   #2
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
I would follow what the manufacturer recommends.
There must be a sticker somewhere on the car, check the glove box.
I would also think that the manual would tell you what you should feed it too.
If I were to guess, I would say that you could use the regular unleaded.
If you hear pinging, go to a higher octane gas.
If you have an '86, then your compression ratio is 9.2:1
That does not sound so high to me.
High compression ratio engines and forced induction engines (supercharged/turbocharged) will need higher octane fuel so they don't ping.
Unless you have a lot of carbon build up (which would increase your actual compression ratio), I would bet that the regular is good enough for you.
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel Octane scruffboy Non-Generation Specific Questions 3 09-08-2006 06:49 PM
