Old 01-27-2005, 12:09 AM   #1
hangsupra
i want to swap my 85 mk2 with an mk3 1jz twin turbo. would the engine mount from the mk2 fit the mk3 1jz engine. do any body know. if not fits on mk2 supra than what kind of engine i can swap? do any body know.
Old 01-27-2005, 12:44 PM   #2
well you can certainly make anything fit... the 1jz will need custom mounts to sit on the mk2 crossmember but any engineer should be able to make those for you
if custom mounts are too hard then you could slap in the 7mgte which has been done a few times so there should be info on the google train
Old 01-28-2005, 04:03 AM   #3
hangsupra
so do i mounts both side of my mk2 engine mount or which side of the engine mount...only one side or both side.....
Old 02-06-2005, 05:13 PM   #4
82supraTT
82supraTT is on a distinguished road
my 82 has a 2jztt and both mounts must be custom being a welder it comes in handy it toook me 2 monthes to sort the wiring, mounts, fuel pump....etc.. good luck anything is possible
82supraTT is offline   Reply With Quote
Old 02-07-2005, 11:18 PM   #5
hangsupra
thank you i look forward to it....and see what i can do to it....thank you....by the way...what state or city you were from...i from 209 area in cali...nice to hear from you...thank you..
Old 02-07-2005, 11:20 PM   #6
hangsupra
Old 02-10-2005, 09:51 AM   #7
7MA61
7MA61 is on a distinguished road
Or u could go a 7mgte all the original supra mouts will bolt stright up. Even your original sump. just have to modify the oil pick up and oil filter and some other minor modifications...
Chase.
7MA61 is offline   Reply With Quote
Old 02-13-2005, 12:51 AM   #8
hangsupra
Chase.
hope that work...thank you....for the info...thank you....
engine swap ! NYTRYDR MKIII Supra 13 08-11-2007 05:37 AM
