Old 04-18-2012, 11:28 PM   #1
dizz212
dizz212 is on a distinguished road
Default Need obd system to check error codes!
Hi guys im in southern California and if anyone has an obd system I can borrow or go use to check for an error code plz message me it would help! I have an 85 toyota supra.
dizz212 is offline   Reply With Quote
Old 04-19-2012, 12:05 AM   #2
You don't need any external system to check the codes on either of the type of ECU which the MKII came with. I believe that the '85 has the TCCS system in which case diagnosis is the same as it is for the MKIII. Refer to the MKIII FAQ section for a thread on checking diagnostic/error codes.
Old 04-19-2012, 11:29 PM   #3
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=22
what problems are you having?
Old 04-23-2012, 08:28 PM   #4
What year did they switch the diagnostics system? Was it just certain models after a certain year or jus '86 models? The had the round harness connector for most of it, i know, but I was certain it changed to the TCCS system toward the end.
Old 04-23-2012, 11:09 PM   #5
82 has the vacuum advanced dist. and it goes electronic in 83 and im sure its the same though 84.
in 85 we got a different style tps, and egr system, a factory alarm and a knock sensor. carries through 1986.
the 9pin & 13pin is a Pre-TCCS ecu (82')
the 10pin, 18pin & 24pin is a TCCS ecu (83'-86')
Old 05-28-2012, 10:44 PM   #6
dizz212
how do I get my hands on a ctts system because I went to auto parts place and they dont have any way for me to check my error codes. I really think my car has a MAF sensor probem
Old 05-28-2012, 10:49 PM   #7
dizz212
canadianbakinsupra that manual would be helpful but on my mkII my check engine light doesnt stay on. It only blinks a bit when engine is on and I have it in park, when I give it some gas and its in low rpm the check engine light blinks a bit then engine chokes and car dies.
Old 05-28-2012, 11:55 PM   #8
like cre said in the second post. you can manually check error codes on both ecu's. try searching around and see what comes up for the 82 style ecu.
i would really check www.celicasupra.com search everything. once agian, you can test your AIR FLOW METER. your car has NO "maf"
refer to your repair manual for testing.
Intercooler system choices? Need help to choose. Bl@ckh3art MKIV Supra 5 05-22-2011 01:59 AM
Cold Start System Testing (hard starting) mrnickleye MKIII Supra 12 11-13-2010 08:32 PM
Exhaust system & components Krem MKIII Supra 6 05-27-2010 12:35 PM
5m-ge check connectors tonster MKII Supra 2 04-08-2006 06:54 PM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
