Old 03-01-2011, 02:17 AM   #1
amueller626
amueller626 is on a distinguished road
Default 86 Supra engine removal
Can the engine be removed without pulling the 5 speed transmission too? What has to be done to free the engine from the manual transmission? The book says remove them together but I don't see why.
Thanks,
Bill
amueller626 is offline   Reply With Quote
Old 03-01-2011, 02:42 AM   #2
Thanks,
Bill
Because it's utterly miserable. The higher you get on the bell housing the harder it is to get to the bolts. I don't think it's a killer, but you still have to unbolt the transmission hanger, remove the drive shaft, get a tranny jack under the transmission.... I think you get the picture. It really is easier and quicker to pull it all (at least that's how most of us feel).
Old 03-01-2011, 04:22 PM   #3
Travis89Turbo
Travis89Turbo's Avatar
Agreed. 100% QUICKER AND EASIER!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 03-02-2011, 01:26 AM   #4
agreed, in the long run. pulling trans and engine will take less time.
it does not take much time to remove the drive shaft.
Old 03-03-2011, 09:56 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
Yep me too, totally agree.
Old 03-21-2011, 07:52 PM   #6
amueller626
Default Jdm 7mge
The JDM engine I'm looking at is listed as 87-92. Will it fit my 86.5 Supra. Also, they recommend chaging the oil pick up and pump. What's the reason?
Thanks!
Old 03-22-2011, 03:18 PM   #7
know one is going to explain every detail. i will point you in the right direction , but it is UP TO YOU TO READ.
http://www.celicasupra.com/forums/fo...5-Engine-Swaps
there are very detailed posts, for engine swaps for the 5/6/7m engines and the 1/2j engines even some threads for the 1uz-fe and other v8s
READ every sticky you can find and dont pass up any info...
this is all about the 1982-86 Toyota celica supra mkII
if i can answer any small questions about my post i would be happy to, but don't ask the people at celicasupra.com they will only razz you for not reading...
GOOD LUCK
1JZ Engine Swap into '89 Supra kyosukerob MKIII Supra 2 10-20-2009 07:49 AM
1987 toyota supra wit 89 7mge engine. Rob1 Non-Generation Specific Questions 1 10-01-2009 02:38 AM
1990 supra turbo engine issues help jespat Non-Generation Specific Questions 4 01-24-2008 02:37 AM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
