Go Back   Toyota Supra Forums! Join the Supra forum! > Supra Specific > Car Audio and Alarms
Old 03-30-2005, 01:08 AM   #1
rude1978
rude1978 is on a distinguished road
I have had battery problems on my TT and now the standard stereo is locked. Is there a way of unlocking it myself, I just know that Toyota will charge an arm and a leg for it.
thanks
rude1978 is offline   Reply With Quote
Old 05-22-2005, 09:18 AM   #2
bhf56a
bhf56a is on a distinguished road
I recently inherited a 1989 Supra Turbo. The radio does not power on, the fuse is good, can this be due to the theft prevention? Is there anything I can do without some code other than to take it to the dealer?
bhf56a is offline   Reply With Quote
Old 05-22-2005, 11:09 AM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
rude1978: if you are lucky you might have the owners manual for your car... have a flick through it and see if the code has been written down somewhere... have a look anywhere in the car thinking if it was you where you would write it down
if no luck with owners manuals for it... try your local toyota dealer
all you should need is the serial number of the stereo and your make and model of car i believe... they should be able to just give you the pin and instructions on how to unlock it
bhf56a: i don't remember any theft deterrent on mk3's
i would actually pull the radio and i bet you'll find shoddy wiring... power wire may have just pulled apart or something
or the stereo may be fried.. pull it and check it out
Pics of my build.
Do a diagnostic first!
anyone install aftermarket stereo? dannydavi Car Audio and Alarms 10 03-17-2012 10:41 PM
Should i retorque my standard headbolts? Gunnar MKIII Supra 3 10-05-2007 07:51 PM
Stock Stereo theft deterrent system Murd MKIII Supra 2 10-18-2006 12:24 AM
factory stereo monkihead Car Audio and Alarms 0 04-02-2005 08:57 PM
